Fs - 1 pair of rss tarmac series lower control arms
Old Apr 12, 2014 | 10:10 PM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
Price: $800
Location (State): SC
I have a spare set of RSS Lower Control Arms from the suspension project I just completed. I had bought 1 pair first then bought a complete setup with toe-steer kits, rear dog-bones, etc from another member so I ended up with 6 LCAs.
These are over $1,000 directly from RSS plus shipping - Save about 25% with this set and get free insured ground shipping.
This pair has the upgraded 2-hole bushing that allows for caster adjustment and would be model #357 as a set from RSS or has the #318 bushing in them. If you need the RSS bushing for the hydraulic OEM version, it's part #323.
http://rss.rpmware.com/rss/rss_tarma.../i-398277.aspx
They will fit the rear of any 996, 997, 986, or 987 and the fronts of any of these cars that do NOT have the thicker hydraulic bushing. You can still use the arms, you'll just need to order the other bushing set (#323) from RSS of one of their sales channels. Arms do not come with any camber shims but are straight and true - RSS strongly suggests using new tapered mounting pins when installing, and these can also be purchased separately from them as well.
These are difficult to find used as no one wants to give them up once installed since they tighten up the handling and precision of your Porsche and make it drive like it should have from the factory !
PM me or e-mail to petza914@gmail.com.
Name:	IMG_5001 (Copy).JPG
ID:	359178   Click image for larger version
Name:	IMG_5002 (Copy).JPG
ID:	359179   Click image for larger version
Name:	IMG_5003 (Copy).JPG
ID:	359180   Click image for larger version
Name:	IMG_5004 (Copy).JPG
ID:	359181   Click image for larger version
Name:	IMG_4974 (Copy).JPG
Old Apr 13, 2014 | 06:26 AM
Tim941NYC's Avatar
Those look to be the old style tapper pins. There is a updated pin that you should use. I heard that the older pin was failing.
Old Apr 13, 2014 | 07:27 AM
Petza914's Avatar
Thanks for the info; it's why I stated that RSS says new taper pins should be used when installing their LCAs. They are single use items only and since these arms are used, they should be installed with new taper pins.
Old Apr 25, 2014 | 01:39 PM
Petza914's Avatar
Bump for Price Reduction to $750 shipped. I also have a brand new RSS #312 Rear Toe Steer Kit for sale in a separate listing if you're looking to do your complete rear.
https://www.6speedonline.com/forums/...ml#post4099983
If you purchase both, I'll reduce the combined total by an additional $25.
Old Apr 28, 2014 | 05:57 AM
Petza914's Avatar
RSS Lower Control Arms are SOLD.
Rear Toe Steer Kit still available in a separate ad listing. Thanks.
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
