1500whp on Ethanol and 1000whp on 93 Build
Old Jan 28, 2017 | 07:41 PM
  #91
Realife's Avatar
Realife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud of
Originally Posted by porschecayenne92
have you considered doing a wpc treatment or similar for the gears ?
In this case with the anticipated HP/TQ levels the WPC treatment (Shot peening) will not resolve the broken gears.
The WPC will drastically improve the fatigue strength of the gears but not the ultimate strength and will only increase the number of times that the gear can be stress cycled before it fails.
The gears are not wide enough and the material is weak.
Waiting patiantly for stronger gears...rolleyes:
Old Feb 9, 2017 | 10:32 AM
  #92
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Any high boost pulls?
Old Feb 9, 2017 | 01:56 PM
  #93
haven't been back on the dyno yet, hopefully soon
#TeamAIM
Old Feb 21, 2017 | 08:51 AM
  #94
Well it seems like we are rolling again. The EGT module had to go back to get programmed for the ProEFI CAN addresses, but it's back, wired and up and running.
Put Ethanol in it yesterday but it turned out to be E65 winter blend, car made 1100whp on same 16-18 psi climb boost setting.
#TeamAIM
Old Feb 22, 2017 | 06:19 PM
  #95
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
Great job....Car looks the business...screen is straight out of a formula f1 car....this car is going to be braking sound barriers don't be surprised if you propel yourself straight into the future.....off topic do you have any Dynos and info on your alpha 3076 on 93....
Old Feb 26, 2017 | 02:59 PM
  #96
25 psi, pump e85
#TeamAIM
Old Feb 26, 2017 | 03:29 PM
  #97
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
Looks like the engine is making a pretty flat torque curve and has room to go based on this chart. Really impressive
Old Feb 26, 2017 | 04:08 PM
  #98
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Mark,
1300AWHP at 25psi, solid numbers my friend!
Something tells me that you have more head room left with your set up!
Old Feb 26, 2017 | 04:30 PM
  #99
Realife's Avatar
1450-1500 around the corner
Old Feb 26, 2017 | 05:43 PM
  #100
Swole Powell's Avatar
Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !
Crazy! Congrats Mark!!
Old Feb 26, 2017 | 08:32 PM
  #101
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Jesus! Congrats Mark!
Old Feb 28, 2017 | 01:03 PM
  #102
thanks guys. going to bump the boost in next few days hopefully. my goal is 1000wtq and whatever whp the car will make to go with that.... should land in 1450 range.
my stock trans and the off the self FVD 3.8L piston kits are the two current weakest links and after 1 year of building I want to get some enjoyment out of it before I destroy some parts.
#TeamAIM
Old Feb 28, 2017 | 04:49 PM
  #103
Realife's Avatar
With your high rpm and such an efficient engine setup to get to the 1000lb wtq you will cross over the 1500 whp and be closer to 1550...
The sound will be unreal.
Counting the hours to start my assembly
Old Feb 28, 2017 | 05:37 PM
  #104
993Godspeed's Avatar
993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !
Stop teasing us and bust out the last dyno graph.
Solid man.
Old Mar 1, 2017 | 08:43 AM
  #105
Made 1340 yesterday on 26 pounds and pump 1.69$/gal ethanol. It would have made more but all I had left was Ignite Ethanol. This is the latest @ 7700 RPM, 35 psi at red line on Ignite Red.
#TeamAIM
