19x12 rear wheels 997.1tt
Subscribe
Dec 24, 2021 | 08:19 AM
Looking at a set of gt2 spec wheels (19x12 eta 68) and was wondering if anyone is running similar w spacers on a 997.1 tt? According to offset calculator with a 15mm spacer the inside clearance to suspension would be reduced by 15mm. Anyone know if this will be ok?
thanks
Reply
Dec 24, 2021 | 05:39 PM
Quote: Looking at a set of gt2 spec wheels (19x12 eta 68) and was wondering if anyone is running similar w spacers on a 997.1 tt? According to offset calculator with a 15mm spacer the inside clearance to suspension would be reduced by 15mm. Anyone know if this will be ok?
thanks
you’ll be fine, I’d suggest 20mm spacers though for a resulting offset of 48mm. I’m running 19x12 ET44. You’re in the wrong forum though.
Reply
Dec 25, 2021 | 04:13 AM
Thanks for the info. I had originally posted in technical forum but moderators moved to here.
Reply
Dec 25, 2021 | 06:38 AM
I run a 19x12 et74 on my NB C2S. Width will fit fine, but you'll need spacers to optimize the offset for the WB.
Only use spacers with the wheel-centric centering flange.
Reply
Dec 28, 2021 | 12:28 PM
Use this https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Reply
Subscribe
