Ciggie lighter doesn't work
Old Dec 19, 2012 | 12:04 PM
jc_333's Avatar
jc_333 is infamous around these parts
Strange problem in that my ciggie lighter doesn't work when I press down. The lighter doesn't lock into position nor does it work with another lighter.
There is power as adaptor to recharge my iPhone works fine. Could it be possible the adaptor has damaged the locking tabs? Can anyone compare their ciggie sockets with my picture to see if anything is different?
Old Dec 19, 2012 | 02:02 PM
Wedgeduck's Avatar
Wedgeduck is infamous around these parts
Quit smoking???
Old Dec 20, 2012 | 12:52 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
IF ashtray FULL or CIG lighter not working.... time to get new car
Old Dec 20, 2012 | 01:09 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
I'll trade you my working cig lighter for your working door boot switch. My dealer says there must be an issue with the door switch since they are backordered. I think is was $800 for one so I told him to forget it and if I want something out of the boot i'll just get out of the car.
Old Apr 18, 2013 | 07:32 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
when you use a phone adaptor in the Bentley cigar liter sockets they like to blow the fuse,pull your fuse panel down and you will see 2 15 amp(blue) fuses on the bottom rail,replace the one that is blown,if it still does't work you will need a new socket which are very easy to fit.
Old Apr 18, 2013 | 10:25 AM
Great answer, thanks for chiming in!
Old Apr 18, 2013 | 12:28 PM
WES77Y's Avatar
WES77Y is infamous around these partsWES77Y is infamous around these parts
What part are you after exactly? as i may have this part in my spares rack.
Regards Gary
Old Apr 18, 2013 | 01:35 PM
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
Check ebay uk, you might be surprised what you find
Old Apr 18, 2013 | 01:44 PM
Regards Gary
The rear boot(trunk) switch in the drivers side door. Give me a price on it if you have one. I am concerned that the labour may be a bit much to get it in so if you take it out give me an idea of real time required to do the job.
Old Apr 22, 2013 | 01:43 PM
WES77Y's Avatar
Sorry Doc, I have had a look and I only have 2 of the trunk badge switches for trunk release, I am over here in the uk and if anything comes up i will point you in the right direction.
Gary
Old Apr 22, 2013 | 01:47 PM
Gary
No worries, thanks.
pshep138
Sep 1, 2015 09:45 AM
oddjob142
Aug 24, 2015 05:49 PM
