Bentley Side View Mirror Puddle Lamp Bulb Replacement (pictures)
Old Jan 19, 2019 | 04:55 AM
John R. Allen's Avatar
John R. Allen is infamous around these parts
Thanks for clarifying, me being a new owner will this work on a 2007 GTC? I also could not open the link to the bulb.
Old Jan 19, 2019 | 02:22 PM
Thanks Pupdogg I pulled my mirrors apart today and will order the bulbs. The write up is spot on!
Old Jan 19, 2019 | 02:27 PM
Does anyone have the part # for the bulbs, none of the links work???? Thanks!
Old Jan 19, 2019 | 05:07 PM
Johnny Hotspur GT's Avatar
Administrator
To be honest, the write up is not spot on, as the writer states it's the turn signal bulb replacement in the side mirrors, which is not....
Old Jan 19, 2019 | 05:10 PM
To be honest, the write up is not spot on, as the write states it's the turn signal bulb replacement in the side mirrors, which is not....
I was not knit picking, the write up and pictures are Great so is his effort in posting. I got the just of the write up.
Old Jan 19, 2019 | 05:12 PM
Administrator
The links are from 2013 IIRC, so dead, the bulb is a wedge bulb, number 194, or W5W known as "N0177535" as per Scuderia for incandescent 194/w5w = https://www.scuderiacarparts.com/par...d-mj-2015.html
Google search = https://www.google.com/search?biw=13...67.eG5HxZk0KY8
Old Jan 19, 2019 | 05:14 PM
Administrator
And to be clear, you are asking for the puddle light bulb number, correct ?
Old Jan 19, 2019 | 05:15 PM
THANKS!!!! I will order a couple right now.
Old Jan 19, 2019 | 05:17 PM
Yes...Thanks! I like the brightness compared to the incandescent that is original.
Old Jan 19, 2019 | 05:25 PM
Administrator
Just so I am clear, the Scuderia link is for the original incandescent bulb for use as a part number reference, the Google search is for the same bulb numbers in LED format.
Old Mar 21, 2020 | 08:34 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
For those who has removed the side mirrors..
Just getting around to changing over to LED’s and I can’t get the mirror back on. So I check a few threads and notice that this white piece I have arrowed in the picture is still on the back of my mirror and not attached to the motor assembly as I see every picture with the mirror out. Did I break something or is this repairable? Whatever that piece is whatever it’s attached too a small piece came off and stayed with it.
Old Mar 21, 2020 | 10:47 AM
Administrator
​​​​​​Hello @TeamJones1962 TJ,
Sorry to say but, I think you may have broken the two pins so to say off the sides of the white plastic piece, what's odd is that it stayed on the mirror, maybe someone in the past glued the mirror backing to it ?
I have the pieces shown in my pictures below, willing to part with some, which side do you need ?
Johnny
Old Mar 21, 2020 | 12:17 PM
Veteran: Navy
Thanks for the reply JHS...
drivers side but I might just get both, I still have to do the passengers side. I can take a better picture when I get home so you can actually see what I have going on.
Old Mar 21, 2020 | 03:51 PM
Veteran: Navy
Here’s what I have Johnny....
Ok, after looking at your pictures Johnny I think I see what happened. That large circle piece came off WITH the mirror.
Old Mar 21, 2020 | 04:01 PM
Administrator
Holy crap, the mirror did not properly separate from the motor housing...
Pulled the gear shafts right out.
