Camshaft sensor bank B.
Old Sep 16, 2013 | 01:09 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi.
I have twice recently had the MIL lamp come on.
When I checked the fault it turned out to be the Camshaft sensor bank B.
Not a major problem I thought, until I read the 'IETIS' manual and found out that the engine needs to be removed to change this part. What a nightmare!
Anyone else had this problem and what's the financial damage for engine removal?
I'm also thinking that if the engine is out, then the others should be changed too.
Mileage is just over 53K so I am a bit miffed.
Les.
Old Sep 16, 2013 | 04:08 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
before just condemning sensor i would check the wiring and carry out a pin drag on the ecm in question,you have the wiring diags on the CD so should not be too hard.
Old Sep 16, 2013 | 08:12 AM
ExSF's Avatar
Thanks Bentleytech.
That sounds complicated to me but I will have a look.
I did 'T-cut' and clean the engine bay the other day so maybe I upset something.
Regards. Les.
Old Sep 16, 2013 | 08:17 AM
well it is not as hard as you think, check wiring diagram to see which control module and pin number and just check for corrosion,damp etc. then check continuity to sensor if poss. i would hate for you to drop engine etc and replace sensor to no avail !
Old Sep 16, 2013 | 08:28 AM
ExSF's Avatar
Me too! It would have to be a dealer job. My days of fitting V8's to Ford Cortina's is well over.
Thanks again.
Les.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Oct 7, 2015 12:55 PM
BMW //M
Oct 5, 2015 12:00 PM
