Help with Nokia mobile.
Old Sep 16, 2013 | 09:54 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
My Nokia 6310i arrived today but upon fitting it into the holder I get a message stating 'Phone unavailable'.
The manual states that a Pin number 'may' be needed, but is it necessary? My phone isn't set up with a Pin at the moment.
The car had a 'Bury' Bluetooth unit fitted when I bought it, but I removed it as it was faulty.
I'm hoping that whoever fitted the 'Bury' unit didn't do away with part of the original system in some way.
Any idea's anyone?
Regards. Les.
Old Sep 16, 2013 | 10:42 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Pin the probably the SIM pin, I think those are usually 0000 but call whomever you got the SIM from just to be sure.
Old Sep 16, 2013 | 01:58 PM
carlosC4S's Avatar
carlosC4S is infamous around these parts
I just bought a Nokia 6100 and it works fine, no PIN needed. I think the cradle fitments allow for 6100 and 6310, mine being a 2005 car took the 6100.
I bought the SIM new about 9 months ago for my Porsche and it worked in that car too so perhaps that has something to do with my success?
Old Sep 16, 2013 | 03:05 PM
ExSF's Avatar
I've been using the Sim for a couple of years in my Jaguar so I know it's OK.
There must be another problem somewhere.
Hopefully the 6310i is the same as the 6310.
The Bentley is a 2004 if that helps.
I will try again tomorrow.
Regards. Les.
Old Sep 19, 2013 | 02:29 AM
ExSF's Avatar
Still no luck. The system doesn't even ask for a Sim. I just get the phone unavailable message.
Back to the drawing board.
Les.
Old Sep 19, 2013 | 06:17 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
they have probably removed the phone control module which in your car is accessed inside the trunk. have you got a vas or vag com, can you see if you can talk to phone module.
Old Sep 19, 2013 | 07:03 AM
ExSF's Avatar
Hi Bentleytech.
I've tried all sorts but to no avail. Even tried adding a pin to the phone.
I don't have vas or vag com but I do have an Autel MOT Pro. I will see if that can cast any light on things.
The Nokia phone does charge and it shows a little car symbol on the screen when the ignition is switched on.
Regards. Les.
Old Sep 19, 2013 | 07:59 AM
have you got the CD with the wiring diags on,if you have you will se the control module location and it is accessed via the trunk,8 or 10 torx screws hold the trunk carpet trim in place and if you lower that you will see if control module is there.
Old Sep 19, 2013 | 08:39 AM
ExSF's Avatar
Many thanks Bentleytech.
I will have a look.
Les.
Hossfly
Merchandise For Sale / Wanted
Mar 21, 2007 04:57 PM
KSA Turbo
Jul 2, 2005 07:42 AM
DEETZ
Apr 10, 2004 04:16 PM
