Windscreen washer system.
Old Sep 20, 2013 | 07:37 AM
silentspeed's Avatar
silentspeed is infamous around these parts
I have the LHD 05 CGT, I have read what I can on the location of both washer pumps. How do I get to them to confirm why they have no pressure? Anyone have thoughts or pictures? The diagrams I have seen have part numbers and a general layout but not of any help.
Old Sep 20, 2013 | 09:04 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Just a thought, I presume that you have tried them with the low beam lights on.
I doubt that they will work with the lights off.
Regards. Les.
Old Sep 20, 2013 | 03:41 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
the washer bottle and pumps can be accessed by removing the passenger side inner fender. can you hear them running ?
Old Sep 20, 2013 | 09:40 PM
Interesting, I will go try that.
Regards. Les.
That is odd... Hadn't even considered that..
Old Sep 20, 2013 | 09:46 PM
No difference that I could tell from having low beams on. I do make sure the car is started or accessories are active.
Old Sep 20, 2013 | 09:48 PM
Yes the windscreen pump sounds like it should be working, then if I keep it activated, the headlight washers work perfectly.
Old Sep 26, 2013 | 12:10 PM
Thank you, is removing the inner fender something I could do or would it require special tools? I would like to check to see if the line(s) is clogged or something.
Old Sep 26, 2013 | 02:01 PM
no just remove wheel and inner fender is held with torx screws,i think it is a T15 ,there is a plastic cap in one area which just pops off,the rest is screws. can you hear the motors buzz when you operate switch ?
Old Sep 26, 2013 | 04:15 PM
Thank you, yes... both units sound like they should work. The windscreen doesn't spray, but the headlights do work as expected.
Old Sep 26, 2013 | 05:07 PM
oh i forgot you will need a 10mm socket for underneath ,i think there are two nuts at rear part of inner fender to remove,then just blow through and it should clear.
Old Sep 26, 2013 | 11:34 PM
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
Here are a few pics for reference....Hope this helps.
[IMG][/IMG]
[IMG][/IMG]
Old Sep 27, 2013 | 07:38 AM
[IMG][/IMG]
[IMG][/IMG]
Excellent, thank you.
COBB Tuning
Nov 3, 2015 08:39 AM
