Control Arms + Tie Rods = $4k Reasonable?
Old Sep 28, 2013 | 01:48 PM
Jmolnar's Avatar
Jmolnar is infamous around these parts
You can use top and bottom arms and drop links if my memory serves right I used an A4 estate reg on an 04 plate the parts place should be able to get it up on their system
I'm not sure what you mean by kickback? Can you explain more?
Old Sep 28, 2013 | 02:15 PM
carlosC4S's Avatar
carlosC4S is infamous around these parts
I thought it was A8 and Phaeton that would work, had no idea about the A4.
When I say kick back I mean I can feel the wheels, as if they are bouncing when the suspension settles after a hump in the road. A bit like fitting wheels that are far too heavy and the unsprung weight has been increased.
I feel it front and back.
Old Sep 29, 2013 | 03:36 AM
Jmolnar's Avatar
Its normally the upper control arms that go possibly lower arms awell thats where id look first
Its a preety simple setup just a case of checking arms/bushes/balljoints
Old Sep 29, 2013 | 03:38 AM
Jmolnar's Avatar
Also check your wheels arent damaged/loose
You would be amazed at the amount of times ive seen wheels that have been newly refurbished and the rim bolts are loose or cross threaded or broken
Jul 29, 2019 11:13 AM
away
Sep 4, 2015 12:30 PM
orbelo
Aug 30, 2015 12:26 PM
spreeon
Aug 27, 2015 08:14 PM
TrackOne
Aug 20, 2015 12:56 PM
