Which system does the gt use
Old Nov 12, 2013 | 12:31 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
I've been swatting up on my 08 GT Speed, however I'm a bit confused as to which ecu system the car uses
KWP1281 or KWP2000 ?????
Does any one know....... the VAS tech manual talks about both and also Crafter and UDS. I know the car doesn't use the last 2.
Any help very much appreciated.
Thanks.
Frank
Old Nov 17, 2013 | 07:23 AM
Any one..........
Old Nov 17, 2013 | 02:41 PM
Digger11's Avatar
Digger11 is infamous around these parts
Frank,
Its not a very technical forum, like many of the other car ones are.
I don't think you'll find an answer to this on here.
Digger
Old Nov 18, 2013 | 06:05 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
are you talking about the engine management system because the Bosch Motronic ME 7.1.1 is used in the Continental series.
Old Nov 18, 2013 | 01:13 PM
Originally Posted by Digger11
Frank,
Thanks digger
Digger
Hi Bentleytech, thanks for the reply.
Yes, it would be nice to read how the ecu adapts to driving/fuel conditions. Especially if 95 fuel has been used for a while.......can the ecu adaption be reset to the factory standard etc etc using the VAS computer etc .
I had a good idea how my 911 worked and using the PST2 computer I could reset adaption values if I felt the ignition had been retarded ( ie the car felt a bit slower).
I'm also interested to know if the tiptronic box can have its adaption values read out and reset. eg the 911 would require a tip adaption reset if it had been driven in a slow manor for too long......it was a common 911 tip problem.
I suppose what I'm after is learning the specifics about the car and how it runs
Old Nov 18, 2013 | 02:00 PM
Hi, yes you can reset the transmission values ,i have some self study files and i will see if i can find the usb i have them on and send them to you,no promises but i will have a good look for them.
Old Nov 18, 2013 | 03:09 PM
If possible that would be great. I think the Bentley is a much more complicated vehicle than the 996 turbo?
Old Nov 19, 2013 | 04:13 AM
I've found some old SSP's that we used for training and i will send them to you if you can give me an email,i hope i can fit the file in or we will have to use a file sharing site. Peter
Old Nov 19, 2013 | 04:36 AM
Thanks Peter.
enquiries@sunnysidebb.co.uk
Frank
Old Nov 19, 2013 | 05:00 AM
hi Frank. ok i have sent a couple,let me know if you want more,i have them for different subjects ,they are pretty basic but may be of some interest.
Old Nov 19, 2013 | 05:29 AM
Brilliant that's what I'm talking about any more info like that is appreciated. I have had a glance through and the info looks just what I'm after. Not that I will be able to use the info but at least I can study up on the car and get a better feel for what I'm driving.
Thanks again,
Frank
Old Nov 19, 2013 | 10:33 AM
hi,i have sent you 3 so far,can you verify you have received 3 because my email keeps popping them up in my "outbox' and i don't want to bombard your email with duplicates.
Old Nov 19, 2013 | 11:01 AM
There great Pate....some good reading for me there. Thanks again PDF format is working well
COBB Tuning
Mar 29, 2016 09:26 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
