large amount of water
Old Apr 14, 2015 | 09:48 PM
jc_333's Avatar
jc_333 is infamous around these parts
Are you sure the rubber seal around your trunk is water tight?
J
Originally Posted by will_wonka
Having raced to the local garage to blow her through, boot holes - nothing came out whatsoever.
It was a hell of a force too.
I'm getting the bucket of water episode when car is washed or it rains 😏 I can see where you blow up, that's done but just where exactly are the inlet or outlets at the other end??
Why oh why did they make it so difficult 😡😡
Thx.
Old Jul 7, 2015 | 10:52 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Recently, my car started depositing loads of water from the aerofoil area when opening the boot. I blew through the drain holes with compressed air. All seemed OK, but the water persisted.
So, today, I removed the boot liner as I was convinced that one of the tubes must be adrift. Sure enough, one was, it had come away from the grommet at the bottom edge of the boot.
Fitted it back on and all is well.
Be careful of the clips though, they may snap.
Les.
Old Nov 19, 2020 | 10:25 AM
Big Blue's Avatar
Big Blue is infamous around these parts
Removing the boot/trunk liner
ExSF you said - I removed the boot liner as I was convinced that one of the tubes must be adrift. Sure enough, one was, it had come away from the grommet at the bottom edge of the boot.
Be careful of the clips though, they may snap. - any chance you could describe how best to take off/remove the Boot/Trunk liner. I TRIED PULLING THE "CARPETING" AWAY BUT NO LUCK. Any luck would be gratefully received.
Old Nov 21, 2020 | 10:33 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
I have a set very similar and would echo Dark Green's words
C
Old Mar 26, 2022 | 03:49 PM
cerex's Avatar
cerex is infamous around these parts
made a video when I maintenanced my car today, hope this helps others
Old Jan 15, 2023 | 01:37 PM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
men - you made a movie , shared on forum, niw is set "private" - great help.
anyone has instruction on boot liner removal?
Old Jan 18, 2023 | 12:58 PM
sazam's Avatar
wanted to do the cleanup on the aerofoil - but can not find any hole under this d
element - where it is?
Feelgood MD
Mar 24, 2016 09:35 AM
AM v12v
Sep 4, 2015 02:52 AM
Sep 3, 2015 04:56 PM
