Hot hot should the car run?
Old Jan 24, 2015 | 07:48 AM
rsprance's Avatar
rsprance is infamous around these parts
I just got a 2007 GT and was curious what a normal temp was for the car to run at. After a few min of light driving it was upward or 200 degrees. Is this a normal temp?
Ryan
Old Jan 24, 2015 | 08:05 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Yes, that is the normal operating temperature
Old Jan 24, 2015 | 03:47 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Dr D is always right, we call him Mr. Right
It should be rock solid at 200F and then stay there pretty much forever. Might as well be like a children's car toy where the sticker reads 200F, as this has been true with both B's over the past four or so years.
Old Jan 26, 2015 | 01:13 PM
glh's Avatar
glh
glh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud of
Mine says 200* all the time once warmed up. Not too clear here but you can tell its at 200...
Winter driving in cold weather around town it might not make it to 200*.
Name:	Bentley speed.jpg
Old Jan 27, 2015 | 10:02 AM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
This operating temperature constancy shows the quality engineering found in the Bentley. After a short time of about two to three miles this car runs at 200 degrees no matter how hot or cold the ambient temperature is.
I think if i saw mine go to 205 or not get past 195 I'd panic. BTW I think they hold the engine heat longer after a rest than most other cars do also. Steady steady steady these things are.
Old Jan 31, 2015 | 07:15 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Mine is the same too. No worries.
Old Feb 15, 2015 | 07:12 PM
ek1's Avatar
ek1
ek1 has a spectacular aura aboutek1 has a spectacular aura aboutek1 has a spectacular aura about
Mine showed just a bit over 200 degrees even after a few laps on a track. Quality engineering indeed.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
barncobob
Aug 19, 2015 02:35 PM
