05 GT Transmission problems?
Old Apr 24, 2015 | 11:14 PM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
Originally Posted by jc_333
In the same position as you as it would be nice to have fresh oil as nothing last forever. My independent quoted below prices using factory recommended oils. Filter not included as pending updated quote but IMO replacing the filter is a must. It would be like changing engine oil without a new filter. Labor $190 ATF (7ltrs) $385 Diff oil (4ltrs) $250 Thanks J
Just make sure if have the scan tool to check transmission temp. if you are going to diy.
Old Apr 25, 2015 | 07:49 AM
jc_333's Avatar
jc_333 is infamous around these parts
Noted with thanks.
Will give it to indy when I replace tensioner damper, pulley and ribbed belt.
J
Old Apr 22, 2017 | 02:28 PM
cl600bill's Avatar
cl600bill is infamous around these parts
Originally Posted by bentleytech
you have to go through a special drive cycle, you will need a very long straight road as it is pretty hard to do, even ZF the makers of the trans know this, we use to complain to them its literally impossible to do without getting a speeding ticket. you have to drive up thru the range at 20-25% throttle and then let it coast to down shift , thats the basics but it is a bit more complicated and you may need a dealer to reset parameters in TCM.
Bentleytech, would it be possible to clarify what is meant by "you have to drive up thru the range at 20-25% throttle and then let it coast to down shift"
Speeds, duration or ??
Thanks, Bill
Old Apr 23, 2017 | 02:25 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
what it means is from standstill, apply 20-25% throttle, let the car go up through each gear till top and then coast to let car slow down and down shift on its own, this is why it is hard ti do. not many roads apart from the freeway give you enough space and the speed you reach is pretty fast before you can start the coasting to slow down.
Old Apr 27, 2017 | 02:30 PM
cl600bill's Avatar
Thanks, Bentleytech. I was able to run through the gears as you suggested on the freeway from a dead stop from the onramp up until 6th gear. I could only coast down to 3rd or 4th before having to speed up due to following traffic. I thought I would have to try it again but yesterday after leaving home to drive around town, the shift was smooth as can be. Don't thing it's a coincidence. Saved me a trip to the dealer and maybe a big repair bill.
To repeat the symptoms, the transmission would always shift from first to second with a hesitation and a "clunk" which seem to get progressively worse. The slower I accelerated, the more pronounced the "clunk". All other shifts were OK.
Is there a simple explanation for what was happening to cause it to heal itself?
Thanks again to Bentleytech!!
Old Oct 15, 2017 | 07:23 PM
jhkm12345's Avatar
jhkm12345 is infamous around these parts
reviving an oldie but a goodie (hopefully)
so I'm trying to replicate this drive cycle to hopefully solve the same set of issues discussed. harsh 3-2 slowing to a stoplight and hesitation on the 1-2 all else is fine and dandy.
A couple questions
was the 20-25% throttle a "by feel" thing or did you hold while watching 25% by use of a obd2 scanner or sort?
possibly interrelated issue but maybe not... when the obd2 scanner is plugged in and the car is off or at idle it shows 13-14 % throttle position. when WOT is applied (when car not running) shows 89% or so
I'll go for another drive tomorrow to see what happens in each case.
Old Jan 10, 2025 | 12:04 PM
virtual_law's Avatar
virtual_law is infamous around these parts
A couple questions
Any closure on this? I am diagnosing something similar on my '05.
Old Jan 10, 2025 | 12:45 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Most likely the accumulator values are bad. They buffer shifts and especially down shifts. There are 6 and they get compressed with age. The sonnax replacements are more robust. The valves are within the transmission throttle body. I've done this project and eliminated the harsh down shift. The job isn't a typical DIY.
https://www.sonnax.com/parts/2678-ac...tor-piston-kit
Old Jan 10, 2025 | 01:17 PM
​​​​​​Thanks! My shifts are okay for the first few KMs, but when I come to a dead stop in traffic, and then creep forward with gentle throttle in d1, it jerks heavy and all tranny indicators light up on the dash and car only has one gear.
​​​​​The sonnax job would require a full fluid drain and fill, right?
Old Jan 10, 2025 | 01:38 PM
5 Year Member
Well it's more involved.. briefly: drain fluid, drop pan, remove tranmission electronic couple, drop tranmission throttle body, remove the tranmission control unit from the tranmission throttle body, separate the two halves of the transmission throttle body and don't loose orientation of the small check *****. Now remove the accumulators and install the new ones. You need to replace the separator plate between the transmission throttle body halves... etc. There is more, this is just a synopsis.
Furthermore I would like to see a clean scan of the transmission control unit since it's defaulting to limp mode. So erase all pre existing codes and than replicate the driving pattern that causes these issues and re scan after a limp mode (all shift lights on) occurrence. This requires RT. VCDS or an equivalent scanner.
EJag66
Bentley
Dec 24, 2020 06:38 AM
camelotceo
Bentley
Dec 18, 2020 08:26 PM
Chiaroblue
Bentley
May 18, 2017 05:36 AM
lefizzet
Bentley
14
Jul 14, 2015 08:17 AM
wooosh
Cayenne 955/957
Feb 23, 2011 09:51 AM
