Transmission fluid change? Can you check temperature with V-scanner V202?
Old Mar 4, 2015 | 09:38 AM
alpa6164's Avatar
alpa6164 is infamous around these parts
I have a Vag V202 scanner and I want to know if you can check the temperature of tranny fluid with this scanner and if so how? My mechanic has the capability to change the fluid, filter and gasket but I hear the temperature has to be at a certain temperature. Also how many quarts/liters and types of fluid does the 6HP26A take? All inputs would be appreciated.
Old Mar 6, 2015 | 07:51 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Service manual says Shell ATF M-1375.4 (Bentley part #: JNV862564A). Note: manual says you must also change the front and centre differential cooling circuit. lubricant oil (Burmah SAF-AG4).
Also note the fluid temperature. Use the VAS 5054A. {navigation} Guided Functions/Component replacement/Select Vehicle System or function/transmission/transmission control/CHECK FLUID LEVEL-TRANSMISSION. The replaced ATF needs to exceed 85C to ensure it fills the cooler circuit.
There are a number of steps required when you change the ATF. If you want full instructions from the IETIS manual, PM me with your email address and I'll provide
Old Mar 7, 2015 | 03:38 PM
BentleyF's Avatar
BentleyF is infamous around these parts
can the scanner check fluid level?
Old Mar 16, 2015 | 02:54 PM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
Hey did you ever figure out if the other scanner works?
Old Nov 26, 2017 | 08:07 PM
tqd7mb's Avatar
tqd7mb is infamous around these parts
Can you send me the instructions please? I have an 06 Spur with 30,000 miles. Low mileage but 11 years old so not certain to change
Old Nov 27, 2017 | 09:41 AM
PMS's Avatar
PMS
If you want instructions, please PM me with your email address. Also note: I don't think you need to change the transmission fluid yet.
Old Jan 1, 2021 | 05:42 PM
Jurgeenh Borbon's Avatar
Jurgeenh Borbon is infamous around these parts
Can you please share to me the instructions? jurgeenh@hotmail.com
Old Jan 2, 2021 | 11:39 AM
PMS's Avatar
PMS
Instructions were sent via email as per your request.
Old Jan 2, 2021 | 07:18 PM
H-M3's Avatar
H-M3 is infamous around these parts
When is it recommended to change the ATF then? Can you please send me the guide. I have sent you PM
thanks
Old Nov 24, 2021 | 09:40 AM
tmech48's Avatar
tmech48 is infamous around these parts
please send instructions for fluid change
Old Nov 24, 2021 | 12:03 PM
tmech48's Avatar
Please send instructions for trans fluid change to tmech48@gmail.com
Old Nov 25, 2021 | 11:28 AM
PMS's Avatar
PMS
Info sent to provided email.
Old May 1, 2022 | 10:57 PM
Sharavan's Avatar
Sharavan is infamous around these parts
Can you please send instructions for trans fluid change to murali66@yahoo.com
Puddlian
Oct 24, 2020 12:33 AM
RickEager
May 1, 2019 09:57 PM
E.C.
Cayenne 955/957
23
Feb 24, 2015 11:05 PM
w00zie
Sep 2, 2010 08:31 AM
