2004 GT Shift Gate issue
Old Apr 17, 2015 | 11:48 AM
onempty's Avatar
onempty is infamous around these parts
Hello All,
My 04 GT has the shift gate issue where the moving sleeve is no longer there. I wanted to know what I can do to fix this and if anyone had any advice on it.
Thank you
Old Apr 17, 2015 | 11:50 AM
onempty's Avatar
here is picture of what I am talking about. The pic shows the black area that slides when you change gears. Mine is no longer there.
Old Apr 17, 2015 | 12:38 PM
larryr's Avatar
larryr has a spectacular aura aboutlarryr has a spectacular aura about
i had same problem on my 04. independent bentley tech charged $900.00
Old Apr 17, 2015 | 01:20 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
For a detailed explanation on this issue, see my post: "05 CGT shifter assembly sliding cover" on this forum.
Last edited by PMS; Oct 17, 2016 at 12:11 PM. Reason: embedded an URL to the original thread
Old Apr 18, 2015 | 11:11 AM
onempty's Avatar
Thank you all so much. Not exactly the easy fix I was hoping for. Where is the best place to get the manual, IETIS service manuals, mentioned?
Thank You
Old Oct 15, 2016 | 09:28 PM
Crazyrussian3685's Avatar
Crazyrussian3685 is infamous around these parts
I have same thing on my 05 continental. Seems to be very common issue. Did lots of research and found out that the only legit fix is thru the dealer. They will have to replace the whole shifter assembly (about $1900.00 + labor). If you will risk it diy fix.. There are bunch of sensors and magnets that you can take out of Allingment and create much bigger issue. I just trained myself not to put anything there that can fall thru the opening. Please post if anyone has better fix!!
Old Oct 17, 2016 | 07:41 AM
Zaos's Avatar
Zaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond repute
I ended up using 2 part epoxy superglue, just reattaching the rubber sliding cover. Been over 6 month and still good
Old Apr 23, 2017 | 12:53 AM
Can u post details or maybe step by step.. on your fix. ??
2lflat4
Nov 18, 2019 05:05 PM
03EvoIII
Sep 21, 2015 04:38 PM
pshep138
Sep 1, 2015 09:45 AM
LiquidElephant
Aug 27, 2015 06:17 PM
