Engine out, 40 hours of labour?
Old Apr 13, 2016 | 01:30 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Originally Posted by blkclk550
I got the same quote from the dealer and spoke to my friend who works for them, he said that dropping engine is a lie and all dealers replace the lines with out engine drop. He's doing mine right now with out droping the engine about 5 hours of work and no where near 10k.
Are you certain that you are referencing the vacuum leak above the transmission? When I removed the driver's side pre-cat, I had a very careful look into the issue and could not see any way to access the junction without removing the engine. I even explored coming in from the top under the shifter assembly (i.e. cutting through the floor). Ultimately, we all concluded this would be even more work than removing the engine/transmission. If your guy has a way to do this without the engine coming out, all of us would VERY much like to know the procedure.
Old Apr 13, 2016 | 01:57 PM
2010supersports's Avatar
2010supersports is infamous around these parts
He is replacing the vacuum lines that crack and do not allow the waste gates to open and throw the engine code. My car would lose power randomly. I went to Bentley and was quotes 10k for this job. Here is my car on a lift, he said all you need to do is take down the plastic above the tires to get in there. He said Bentley then charges for engine drop that never happens.
here is a picture of my car getting the lines changed i will have more soon.
Old Apr 13, 2016 | 02:00 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Maybe they changed the location of the hose from the older 2004 to 20?? design with the newer models?
Old Apr 13, 2016 | 02:01 PM
Originally Posted by stevenrmusic
Maybe they changed the location of the hose from the older 2004 to 20?? design?
Mine is a 2009-2010 model the lines warp around the engine, it was melted not even cracked, i will ask him more info on years.
forgot to add dealer also told me i need new turbos 17k, tech said that's a lie all i need is that line.
Old Apr 13, 2016 | 02:54 PM
Holy !!!!! Am glad there are some great independent service guys near me. So tell us, who is the dealer that said this as we should all know to keep things in mind in the future.
Old Apr 13, 2016 | 10:51 PM
ULSTRUP's Avatar
ULSTRUP is infamous around these parts
I understood from my Indy that as from the 2008 MY they changed the design and that you don't need to take the engine out to replace the line that goes above the transmission.
if he is right, and knowing him I believe he is, it is another proof that the original design was flawed.
having said that, Bentley Mc still insists in taking the engine out in case of a leak above the transmission....
who is right???
Old Apr 14, 2016 | 03:24 PM
blkclk550's Avatar
blkclk550 is infamous around these parts
who is right???
Spoke to my guy he said they are the same on all bentley continental I'm getting them replaced with out engine drop. Lines alone $1500 that's with discount from dealer. 10-12 hours worth of work?
Old Apr 14, 2016 | 03:28 PM
blkclk550's Avatar
New lines now come with heat shields around them. This means they recognize the issue of them melting from heat.
Old Apr 14, 2016 | 03:38 PM
PMS's Avatar
PMS
Thanks for keeping us up to date. Will your guy provide insight into his procedure? I am very curious to see how he gets to the junction at the top of the transmission. Pictures would be of huge benefit.
Old Apr 14, 2016 | 04:49 PM
blkclk550's Avatar
You have to take out the steering rack.
Old Apr 14, 2016 | 11:49 PM
ULSTRUP's Avatar
No, taking out the steering rack doesn't allow you to replace the line above the transmission.
by taking out the steering rack you can replace one of the, various, vacuum line but by no means you can reach the connection above the transmission.
I don't remember the price of the lines but I don't think is even close to $1500, they are cheaper than that. you should check with Flying Spares.
Old Apr 14, 2016 | 11:51 PM
blkclk550's Avatar
Old Apr 15, 2016 | 06:04 PM
blkclk550's Avatar
New lines are in
hehe
Old Apr 16, 2016 | 06:52 AM
PMS's Avatar
PMS
Thank you for the pics. When you originally discovered the vacuum leak (I am assuming a smoke test), where was the leak? Did you replace the vacuum line over the transmission?
Old Apr 16, 2016 | 07:48 AM
Am not home to give exact part#, yet the vacuum leak above the tranny on the 07 GTC was a single hose that was $300 (probably a $75 hose they overcharge you for at 'Bentley pricing' of course).
