Engine out, 40 hours of labour?
Old Mar 18, 2016 | 09:11 AM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Hi,
My 04 just got a check engine light came on. The indy tested it and determined there is vacuum leak.
The labour to take the engine out is 40 hours and the total cost of repair is about $10,000.
Does that sound right?
Old Mar 18, 2016 | 09:17 AM
vettegood's Avatar
vettegood is infamous around these parts
what year , model and mileage is your car???
Old Mar 18, 2016 | 09:30 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Dealer charges around $4000 for the same job on a 2007. Been there, done that
Odds are it is the infamous 'false air' bad hose just above the transmission. Very common problem with early models up to 2008 or so.
Old Mar 18, 2016 | 09:35 AM
paul29's Avatar
paul29 is a splendid one to beholdpaul29 is a splendid one to beholdpaul29 is a splendid one to beholdpaul29 is a splendid one to beholdpaul29 is a splendid one to beholdpaul29 is a splendid one to beholdpaul29 is a splendid one to beholdpaul29 is a splendid one to behold
What is leaking that requires an engine removal? Did the Indy do a smoke test to find the source of the vacuum leak?
Old Mar 18, 2016 | 10:44 AM
lilo1980's Avatar
The car is 2004 and about 43000 miles.
Should I take it to the dealer and get a second opinion?
I already did a $6k suspension job last month and spending $10k doesn't sound very appealing
Old Mar 18, 2016 | 12:03 PM
Have the indy write down WHERE the leak is. Then take it to the dealer.
$10k is outrageously high if it is the typical false air leak. As for the overall ownership costs, it's an early model Bentley so.....
Old Mar 19, 2016 | 01:06 AM
ULSTRUP's Avatar
ULSTRUP is infamous around these parts
on early models 2004/2006 the only leak that needs an ''engine out" is, as Steven says, the hose located above the gearbox.
Bentley Monaco is quoting 4800€ for replacing it.
and Bentley Monaco is about 30% more expensive than any good indy....
10k$ is ridiculous....
Old Mar 19, 2016 | 07:41 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
I sent you a PM. We are in the same location (i.e. GTA).
Old Mar 19, 2016 | 09:18 AM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
I had to take the engine out of my 2005 to change the primary cat and fix the transmission air leak and the job took me roughly 10 hours. I bet thers are shops that will do it for a lot cheaper. 10k sounds way too much!
Old Mar 20, 2016 | 07:50 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
The main dealer in Cheshire UK did mine for around 7k USD equivalent.
Sounds way too high to me.
Les.
Old Mar 25, 2016 | 05:57 PM
lilo1980's Avatar
Thanks guys.
Here is the required parts:
07C919529K
07C919529L
3W0612925BA
3W0612041BB
I can find 07C919529K and 07C919529L from Flying Spares but 3W0612925BA and 3W0612041BB seem to be for 2011 models?
I found these two parts: http://www.flyingspares.com/shop/ben...w0906283b.html
and
Are they the same as 3W0612041BB?
Old Mar 25, 2016 | 11:25 PM
ULSTRUP's Avatar
you should give FS a call and ask them.
they are very helpful and very competent.
Old Mar 26, 2016 | 08:37 AM
PMS's Avatar
PMS
Originally Posted by lilo1980
Thanks guys.
07C919529K
07C919529L
3W0612925BA
3W0612041BB
and
Most of these parts vendors ask for your VIN in order to ensure they are providing the correct parts.
I have had very good luck with Scuderia Systems in the UK. Here's a toll free number: 1 888 527-9396. I deal with Chris (chris@scuderiasystems.com) Their service and prices are very competitive.
Old Apr 13, 2016 | 09:48 AM
blkclk550's Avatar
blkclk550 is infamous around these parts
Hi,
I got the same quote from the dealer and spoke to my friend who works for them, he said that dropping engine is a lie and all dealers replace the lines with out engine drop. He's doing mine right now with out droping the engine about 5 hours of work and no where near 10k.
Old Apr 13, 2016 | 11:48 AM
That is a very serious accusation. Can your friend tell us the procedure for this without dropping the engine.
