Continental GT Judders & Jerks when cold
Old May 10, 2016 | 01:13 PM
neiloakley's Avatar
neiloakley is infamous around these parts
So over the last few months its been getting worse.
When you start the engine from cold (i.e everything is the same as ambient temperature), it idles and accelerates fine, but then when holding a steady speed and light throttle, the car judders like I and playing with the accelerator.
It hard to describe, it's like I am putting the throttle on and off really quickly. If I floor it, or let off completely the car is smooth as silk. Not noticed any dip in performance either.
After a couple of miles, it returns to normal and the juddering jerkiness goes away until the next day.
Any ideas? Car is regularly serviced by Bentley, and no fault codes present.
Old May 13, 2016 | 09:40 AM
neiloakley's Avatar
Any ideas/suggestions from anyone?
Old May 14, 2016 | 03:53 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Does sound like a misfire of some sort Neil.
Hopefully someone will respond over the weekend for you.
Les.
Old May 14, 2016 | 08:34 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
There can be a number of factors that create the symptoms you mention. Do you have any computer diagnostic info? Also, can you provide data on age of vehicle, mileage etc.?
Old May 14, 2016 | 07:17 PM
BentleyF's Avatar
BentleyF is infamous around these parts
Check Mass air flow sensors and fuel pumps it has primary and secondary
one of them just starts the car and only runs for 20 sec or so then 2nd one will kick in also under hard acceleration, i replaced both of mines and th e diffecence was night and day.
Old Feb 15, 2017 | 01:58 PM
jim2331's Avatar
jim2331 is infamous around these parts
...how were your issues finally resolved and what did it cost you to fix...JimB
YBE
Cayenne 955/957
16
Dec 17, 2020 09:31 PM
halb
Aug 16, 2017 09:04 PM
stevenrmusic
Bentley
Mar 26, 2016 08:12 AM
pabafree1995
Mar 24, 2016 05:09 PM
