Having the vacuum hose fixed--what else while they're at it? '09 Flying Spur
Old Jun 24, 2016 | 12:59 PM
cduluk1's Avatar
cduluk1 is infamous around these parts
Hi all:
I have a 2009 Flying Spur with 61,000 miles. Had a check engine light, so took it to Bentley. They discovered a (or should i say, 'THE' dreaded) bad vacuum hose, and currently have the engine apart while the parts come in.
Is there anything else i should have Bentley replace while they have the engine out? I only have 60k miles, but thought it might be prudent to ask you guys if there are any other 'known' parts that might fail in the engine area--to save on labor costs-- if they're going to fail soon anyways in the future.
Can you think of anything? Maybe spark plugs, belts, or other 'hard to reach' components or sensors? If i'm paying upwards of $4,000, most of it labor costs, i might sleep at night knowing i've basically a new engine!
Thanks for ANY input!
Old Jun 24, 2016 | 01:21 PM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
Exhaust gas temp sensors- those are a PITA to do in the car, easy with engine out. The coolant head (set of lines in the front of the motor) are worth doing. Other than that, anything that looks questionable.
Old Jun 24, 2016 | 03:03 PM
larryr's Avatar
larryr has a spectacular aura aboutlarryr has a spectacular aura about
i think starter is " buried" in the engine
Old Jun 24, 2016 | 03:14 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Great suggestions above, and may as well have them check the suspension bushings.
Old Jun 24, 2016 | 05:49 PM
cduluk1's Avatar
GREAT!! Which of everything mentioned above is in the "replace" category and which are in the "check and replace only if" category?
Old Jun 27, 2016 | 07:07 PM
cduluk1's Avatar
any thoughts to what i should ask them to outright replace vs "check" ?
Old Feb 15, 2017 | 11:59 AM
jim2331's Avatar
jim2331 is infamous around these parts
....what has your experience been since major job...what bits did you refresh...what was final bill...any followup visits to correct...JimB
Wildcat1212
Jul 24, 2024 06:23 PM
BeezyGT3
Sep 3, 2016 11:20 AM
OK51MON
Apr 2, 2016 12:45 PM
350ZR
Apr 2, 2016 11:04 AM
