05' Continental GT trunk lid?
Old Aug 4, 2017 | 02:51 PM
davidaragon's Avatar
davidaragon is infamous around these parts
Exclamation 05' Continental GT trunk lid?
Hi,
Just checking since I don't know...
Is the trunk lid supposed to pop up and fully open by itself?
I have the 05' and I press the button and hear noises, i see a bit of movement and then I lift it.
I know that when I close it, it closes it and locks it down.
I wanted to ask so i know and i don't break it any further than I am already
Thanks,
David
Old Aug 5, 2017 | 05:30 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi David.
The early models didn't have full lift or close on the trunk/boot. The noise you mention is normal.
Les.
Old Aug 5, 2017 | 08:23 AM
Thank you
Originally Posted by ExSF
Hi David.
Les.
Thanks Les!
Do you know the different bulbs that I need for the front and rear turn signals, reverse lights, puddle lamps, and the two headlamps? Pretty sure I saw the high beam is a 9005.
Thanks again!
David
Old Aug 6, 2017 | 01:16 AM
ExSF's Avatar
Sorry, no. I did change the side lights/front marker lights to LED's but it's a right pain in the proverbial to do. Three and a half hours I struggled for and had plenty of cuts too.
The LED's were from eBay; http://www.ebay.co.uk/itm/T10-CAR-BU...72.m2749.l2649
I'm sure someone will know what other bulbs you need.
Here's a link to the thread about changing bulbs; https://www.6speedonline.com/forums/...-headlamp.html
Les.
Old Aug 6, 2017 | 09:11 AM
Thank you
Les.
Thanks Les, I appreciate it.
