Bentley Continental GT 2005 Overheating/Power Loss
Old Sep 28, 2017 | 10:10 AM
aleventhal's Avatar
aleventhal is infamous around these parts
Originally Posted by ysf
dear Sammy,
Just i did ask for the sensor by the dealer, but thay say there 2 of this sensors, 1 for the first cilinderbank and 1 for the second cilinderbank, how i can know which cilinderbank i have to change ?
My recollection is that it is the (US LHD) passenger side bank that causes this problem, but I'd change both at the same time - they are cheap enough and if one is bad, the other is sure to follow.
Old Oct 25, 2017 | 10:36 PM
Kamel's Avatar
Kamel is infamous around these parts
same problem
hello
Am facing the very same problem the dealer so far changed the oxygen sensor the gas tempreture sensor cleaned the coolant system and still am having the same warning it costed me thousnads so far and still not fixed kindly advice me.
Old Oct 31, 2017 | 09:16 AM
aleventhal's Avatar
Originally Posted by Kamel
hello
Kamel, did you change both banks' EGT sensors? If the issue is an overheat warning but normal water temp, that's usually the issue. If you did, is your problem still the warning but normal temps? Please clarify.
Thanks,
Alex
Old Nov 2, 2017 | 12:15 AM
Kamel's Avatar
Thanks,
Alex
Thanks Alex for your reply
I changed bank 1 only as this was advised from the dealer cuz it is giving p0545 which is bank 1 but still am having the same overheated when the car doesnt move for 2 to 3 days
Old Nov 2, 2017 | 10:20 AM
aleventhal's Avatar
I guess then I'd start by cleaning / verifying the bank 1 EGT connection and changing the bank 2 sensor as well. Use some Stabilant 22 or equivalent on both connections to be doubly safe.
Old Mar 4, 2018 | 05:16 AM
jc333's Avatar
jc333 is infamous around these partsjc333 is infamous around these parts
Bentley EGT sensor overheating problem solved
Update!
Oh well...good while it lasted. Overheating error popped up once yesterday so although wrapping it does helps it doesnt resolve it completely. Will replace sensor and wrap it again to prolong service life.
Those with this overheating problem can try this method before splashing out for a new EGT sensor.
I had P0545 - Short to ground and also P0544 - Circuit malfunction for bank 1 which causes limp mode. I know its a common issue as I've already replaced the sensor twice within 3years and couldnt believe I needed a third so soon.
Googled around and found EGT sensors are prone to dry solder joint and bad connections from engine heat. I thought no loss trying to reduce temperatures on the EGT PCB housing so mummified the PCB housing and bracket with temperature resistant Tesa tape. I also sanded the grounding points on bracket and cylinder head cover.
Lo and behold.....no more overheating error over the last 2 weeks of driving.
J
Old Mar 9, 2018 | 07:46 AM
sam08861's Avatar
5 Year Member
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Thanks for the update!
Old Aug 23, 2018 | 04:24 PM
yanacha's Avatar
yanacha is infamous around these parts
Hello my friends
For the change of the 2 pieces, did you take away the engine ? Or the change has be done by the top ?
Best regards,
Old Aug 25, 2018 | 01:56 AM
yanacha's Avatar
Hello my friends
Best regards,
Old Aug 25, 2018 | 12:23 PM
Johnny Hotspur GT's Avatar
Administrator
Originally Posted by yanacha
Hello my friends
Best regards,
Hello Yanacha,
The items are accessible from the top, do NOT drop the engine/trans unit.
Johnny
Old Aug 29, 2018 | 04:48 PM
yanacha's Avatar
thanks a lot for your help
what tool did you use?
because impossible with a flat key of 17
Old Aug 31, 2018 | 04:21 AM
yanacha's Avatar
Old Oct 3, 2018 | 03:44 PM
911TT-RS's Avatar
911TT-RS is infamous around these parts
Where can i obtain this tool from please? can you point me to the right directions please.
I have 2006 Flying Spur, need to change passenger sensor.
Old Oct 3, 2018 | 11:36 PM
yanacha's Avatar
hello for the forgotten passenger it is too big in size uses a finer
Old Oct 4, 2018 | 08:55 AM
911TT-RS's Avatar
thank you very much. i will give it a go
