"Normal" tire pressure
Old Jan 3, 2018 | 07:46 PM
MrVette's Avatar
MrVette is infamous around these parts
I like to keep up with my tire pressure. So I hit the "Vehicle" button frequently to bring up the display of normal and actual pressures.
I've noticed that the specified "Normal" pressures for my 20 inch tires changes a bit. Its not always the same number from day-to-day...close but not exactly the same.
Has anyone else noticed this?
Old Jan 4, 2018 | 10:07 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Pressure is a function of ambient temperature. Therefore, your pressures will vary during different periods during the day and night. These pressures can vary as much as four pounds in a 20 inch tire.
Old Jan 4, 2018 | 12:06 PM
MrVette's Avatar
I am familiar with the Gay-Lussac's law defining the temperature and pressure relationship.
But now I realize my post was not clear.
The display shows a "specified" pressure for 3 different driving speeds, including "normal", and the "current" pressure. As you pointed out the current pressure will increase as the tyres warm up. However I have noticed that the specified pressure also jumps around a bit. That's what I do not understand.
Is it possible that the car is so smart that the "specified" pressure climbs a bit after driving a while in recognition that the tyres have warmed up and the "current" pressure has increased?
Next time you take your car out open the Vehicle display and see what the initial specified pressure is for normal driving speeds and see if it changes over time a few degrees like mine does.
Old Jan 4, 2018 | 12:12 PM
PMS's Avatar
PMS
Sadly, I have disarmed my TPMS as I found it unreliable and prone to battery failure in the transmitters. Consequently, I won't be able to answer your question. It does seem plausible that the car is "smart" enough to adjust.
Old Feb 18, 2018 | 07:37 AM
mwang218's Avatar
mwang218 is infamous around these parts
Tire pressure light
how can you turn on the tire pressure warning cause mine stays on and it’s annoying.
Old Feb 19, 2018 | 08:51 AM
PMS's Avatar
PMS
This topic is covered several times in this forum. Here is an example.
race3
Cayenne 958
Dec 2, 2015 09:14 PM
OEM
Sep 18, 2014 05:28 PM
OEM
Apr 14, 2014 08:30 AM
artem-evo
Aug 11, 2012 01:36 PM
bond
Jul 15, 2004 12:59 AM
