Active rear spoiler
Old Apr 12, 2018 | 07:47 PM
Forster1993's Avatar
Forster1993 is infamous around these parts
Active rear spoiler
Bit of a long one.
So I started having my spoiler warning light on the dash on every start up and whilst driving it would pretty much do its own thing. Coming up and going down wheneverw it felt like it. So I stripped the boot down and started using the buttons and found I could lower the spoiler but couldn't raise it. I then found that ifif raised the spoiler using the bolt in the boot and then pressed the button to raise it it would still go down.
So I removed the motor and left it connected and sure enough the drive gear turned anti clockwise regardless of which button I pressed.
After opening up the motor casing I found some corrosion on the boat
So I cleaned the board up but unfortunately the corrosion appears to have gotten into the multi layer board as this had no effect.
What I did find on one of the Lambo forums is that if you make a jumper wire to link out pins 4 and 10 you can remove the motor completely and will never have an error on the dash
3WDistributing
Nov 3, 2015 01:12 PM
Mish_Mish
Jan 2, 2015 09:52 AM
No32
Jul 7, 2014 05:20 AM
rufc4s
Nov 14, 2013 10:52 AM
intofx
Jun 15, 2011 12:40 AM
