Bentley Arnage T (2007) ABS warning light
Old Jan 10, 2019 | 04:42 PM
airbusdrvr's Avatar
airbusdrvr is infamous around these parts
When I start the engine (applying light pressure to brake to activate start button), everything is fine
BUT if i apply medium to high pressure after start, I get a steady ABS warning symbol that doesnt go away. I removed and visually checked the wheel speed sensors, hoping one was knicked or had a broken wire. All appeared ok. Brake fluid level is ok. I do hear a clicking...or light thumping sound coming from inside the center counsel (probably in the tunnel) when i press the brakes. Is this a normal solenoid sound? Could this be my issue? What is making that sound? Brakes appear to operate normal. I did the pressure regulator (booster) test by pressing brake 20 times (with engine off). While leaving foot on brake, i started the engine and pedal dropped as described by service manual.
Any ideas? Brake accumulator?? Booster???
FXRcR1
Bentley
Feb 25, 2017 10:10 AM
riozilla
Oct 2, 2016 07:37 PM
riozilla
Bentley
Nov 26, 2015 06:43 PM
davetherave
Bentley
Sep 16, 2015 06:30 AM
Global Autosports
Bentley Vendor Classifieds
Mar 18, 2012 11:23 PM
