Plenum clean out
Old Feb 15, 2019 | 05:19 AM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
Plenum clean out
Hi guys was looking to clear the front bulkhead drains 2004 BC gt.I've removed passenger wiper but driver's side won't budge is there a special puller as the three I have won't fit inside the plastic cowl cover.then could someone give me an idea possible a picture of where the drains are located and best way to clear .I have access to airline and can make something up if required thanks.sorry if this is a repeat post but couldn't find any pics of what I was meant to be looking at thanks
Old Feb 15, 2019 | 07:00 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
No tools required. Look online how to remove Volkswagen wiper arm. The first time I did mine I was a bit kerfuffled.
Basically, lift the wiper blade away from the windshield and then wiggle the base until it comes off.
Old Feb 15, 2019 | 07:14 AM
Yea I've tried I don't think this thing has been serviced or cared for the wiper arm is jammed tight.ive soaked in release spray for days and still no movement I don't wanna try to much as it's right next to windscreen
Old Feb 15, 2019 | 07:39 AM
5 Year Member
Try using a heat gun or even a hair dryer. Ran into the same problem too easy to scratch the hood of the car using a puller.
Old Feb 15, 2019 | 07:45 AM
ThaTha mate will give it a try .are the drains easy to locate not had a look in there yet
Old Feb 15, 2019 | 07:59 AM
5 Year Member
I used compressed air to clean the plenum. Lots of small leaves blew out. Wear a dust mask. A vacuum cleaner can't get into all the spaces. Once done run clearwater through to make sure they are draining. I don't remember seeing the specific location of the drains.
The design/ engineering department scratched their heads; where do we put all these important modules and wires. Why not put them in the recessed area where all the water from the windshield goes. The same department came up with the plastic vacuum lines. Well, looks good on paper.
Old Feb 15, 2019 | 10:29 AM
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
I made this to get mine off
As mine where proper stuck
Old Feb 15, 2019 | 12:53 PM
Cant see a picture I'm thinj by if making my own so would be good to see
Old Feb 16, 2019 | 12:53 AM
joc44's Avatar
Not sure why, i can see it on the thread.
Old Feb 16, 2019 | 04:46 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
I second that also, just a little box. I’m on an iPhone if that helps. I’ll try from an android later.
Old Feb 16, 2019 | 08:06 AM
joc44's Avatar
Old Feb 18, 2019 | 12:51 AM
joc44's Avatar
i made this to get mine off
as mine where proper stuck
tap the box
Old Feb 18, 2019 | 05:30 AM
tap the box
Ah can see it now thanks I'll see what I can knock up 👍
Old Feb 18, 2019 | 10:01 AM
joc44's Avatar
something like this
ABCar
Jan 24, 2010 06:18 PM
pekopeeus
Jan 30, 2009 09:01 PM
dduncan
Apr 23, 2008 06:25 PM
