Anyone had P0455 Large Evap Leak???
Old Feb 26, 2019 | 01:52 PM
Dave01gt's Avatar
Dave01gt is infamous around these parts
I searched and couldn't find anything. I got the check gas cap the past 2 days and now have a check engine light for P0455 large evap system leak. Is there a known issue with the Bentley gas caps or any other issues with charcoal canister or rear evap lines? I just got finished doing the vacuum line replacement with brake lines. Just trying to see if anyone else has had a similar issue before throwing parts at it.
Old Feb 26, 2019 | 02:11 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Smoke test right side(passenger US) 13mm/1/2in vac. line. Carefully undo factory check valve, leaving it attached to the rear of the intake manifold. The line to test should be independent of any sensors. Many forget to repace this larger line. This is the evap control line.
Old Feb 26, 2019 | 02:58 PM
Dave01gt's Avatar
Thanks. Would it not show up from a smoke test from removing the factory pump line and smoking from there? like I did to find the cracked lines behind the steering rack?
Old Feb 26, 2019 | 03:46 PM
5 Year Member
No, Evap vacume is controled on the right side and is independent of the vac. pump. The other side is on vac pump for the brakes.
Old Feb 26, 2019 | 04:39 PM
5 Year Member
By the way :There is also an evap purge valve by the radiator overflow fill container. A visual check of this as well. The line going to the gas tank can crack, or the nipple on the purge valve breaks off.
Old Feb 27, 2019 | 02:58 PM
Dave01gt's Avatar
Thanks for all of the help. Would smoke testing it here in this picture word for the evap side?
Old Feb 27, 2019 | 03:19 PM
5 Year Member
That's it.
My suspicion is, that pipe is crumbly since there's a rubber hose on it. What happens, handling it cracks at the metal junction behind the steering rack and pinion. Hope I'm wrong.
Keep us posted.
Unfortunately the online videos don't show this line and the other side line being repair in metal. I've done them with soft half-inch copper tubing. The trick is to fill the tube with sand pound the ends shut and do all the bending. This way you don't get crimping. Then cut the pounded ends off and blow out the tube diligently.
Old Feb 27, 2019 | 03:24 PM
Dave01gt's Avatar
That's it.
Keep us posted.
Thanks again. Do I need to cap anything off like I did on the intake in order to do the smoke test correctly?
Old Feb 27, 2019 | 03:39 PM
5 Year Member
You're good to go. No capping off.
Old Jul 27, 2020 | 12:39 PM
fstick09's Avatar
Registered PM
fstick09 is infamous around these parts
Hey Dave,
I know this is an old thread, but did you ever clear your P0455? I have the same code in my 07 GTC.
Gary
Old Jul 27, 2020 | 01:27 PM
Dave01gt's Avatar
Originally Posted by fstick09
Hey Dave,
Gary
The rubbers ends I used to connect the hardlines I used for the vacuum lines split and had to do it all over again. Definitely a vacuum leak.i used a smoke machine to find them all.
Old Jul 27, 2020 | 03:06 PM
fstick09's Avatar
Registered PM
Where were those connections? I haven't started my inspection process yet
Old Jul 27, 2020 | 05:29 PM
Dave01gt's Avatar
since yours is a 06+, they usually leak behind the steering column up on the firewall and again at the back of the intake.. it's not a fun task if that's where your vacuum leak is.
Old Apr 9, 2023 | 06:08 PM
youngjefe's Avatar
youngjefe is infamous around these parts
did you smoke test it from this vacuum line?
vtraudt
Bentley
Sep 11, 2019 01:59 PM
ULSTRUP
Bentley
23
Apr 23, 2017 07:27 PM
VGLNTE1
Sep 25, 2016 11:31 AM
milk911
Mar 2, 2011 06:34 PM
