Driver side window alignment
Old May 24, 2019 | 04:05 PM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
Hi guys I've recently re installed the front window on my Bentley GT 2004 and I just can't get it to work/align properly.i fitted the regulator 6 months ago and it's been fine but I had to remove the window pane but since fitting it again it hits the rubber on the quarter window but it's not central so when driving the wind whistles through.i tried every combination to set it straight but just can't find the correct position is there a simple way to do this.its annoying because everytime I want to test and adjust I have to dissemble the whole door card
Old May 24, 2019 | 10:32 PM
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
Hi only me again ... Dose the door and the quarter panel glass drop when you open the door or go back up when you close the door ...
Old May 25, 2019 | 01:03 AM
Hi Rico yes I've set the windows up they drop as they should and operate properly it's just at the very top of the window seems.to bend.inwards when fully closed I've tried the adjuster plate on the back leg but it was fine before I just can't work it out
Old May 25, 2019 | 01:55 AM
Rico.Adams's Avatar
5 Year Member
Yah it doesn't sound great but let fix this, ok take the door card off and behind the bass speaker which is the round one remove it, when you totally lower the window a alloy comes down with the glass have you aligned this with the glass and the runner.
I'm taking my door cards off today to replace some speakers I'll have a good look what and get back to you later today ...
Old May 25, 2019 | 02:22 AM
Thanks Rico because I had to remove all door panel inside originally to fix door handles and I didn't realise there was alignment behind speaker as I've never removed the speaker I guess I must of got lucky when I replaced the regulator months ago.in my thread "please help" you can see the hassle I've had with the door handles 🙈. I'm away this weekend but will get straight back to it on Monday thankyou
Old May 26, 2019 | 10:20 AM
Rico.Adams's Avatar
5 Year Member
Hello Yoghurtshotgun, I hope this helps, you can level the glass at these points once you remove the speaker ...
Old Jun 9, 2019 | 12:35 PM
Ok so spent my Sunday with the other wife and tackled this window issue it turns out the guy who wrapped the car put the quaterlight window adjuster at the bottom in wrong making the top of the window curve out more at the top.so happy I found the issue always best to check others work now days as some are a lot worse than others .on to the next task!!
Old Jun 9, 2019 | 12:41 PM
Rico.Adams's Avatar
5 Year Member
Glad you got that sorted ...
nottoshabi
Nov 22, 2013 03:49 AM
Carbon
Jul 31, 2011 03:50 PM
bad107
Dec 15, 2009 05:09 PM
bryantjew
Jan 28, 2008 02:57 PM
