Fault codes
Fault codes
Hello everyone!
Scanned the car (2006 Continental, slightly over 27000 miles on the clock), got the following fault codes:
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D
Component: ESP 5.7 4WD H01 0021
Coding: 0007878
Shop #: WSC 03130 000 00000
VCID: 3635276C3453EFD720B-51F2
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 A HW: 5WK 470 26
Component: 1Y Kessy 6700
Revision: 67005514 Serial number: VWZ3Z0E7349396
Coding: 0405741
Shop #: WSC 00083 000 00000
VCID: 2517F02099F5944F991-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 F
Component: ZAB COCKPIT 0251
Coding: 0400325
VCID: 30391174D637C1E77A7-5160
1 Fault Found:
00384 - Optical Databus
004 - No Signal/Communication
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000107
VCID: 2F3B1208CB09DE1F63D-5160
1 Fault Found:
00907 - Intervention load Management
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000212
1 Fault Found:
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication - Intermittent
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0703
Coding: 0000157
VCID: 3635276C3453EFD720B-5160
2 Faults Found:
00211 - Control Circuit for Rear Illumination Lights
000 - -
01330 - Central Control Module for Central Convenience (J393)
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 4S HSG 0101
Coding: 0000034
VCID: 33331E782721FAFF075-4B00
Subsystem 1 - Part No: 3W8 959 701 B
Component: Tuersteuergeraet FS 1002
Subsystem 2 - Part No: 3W8 959 702 B
Component: Tuersteuergeraet BF 1002
Subsystem 3 - Part No: 3W8 959 703 A
Component: Tuersteuergeraet HL 1002
Subsystem 4 - Part No: 3W8 959 704 A
Component: Tuersteuergeraet HR 1002
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022401
VCID: 353720602955E4CF291-5160
1 Fault Found:
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 123
Time Indication: 0
Freeze Frame:
Voltage: 13.77 V
Count: 231
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 C
Component: Wische(
Shop #: WSC 00000 725 65552
3 Faults Found:
00003 - Control Module
014 - Defective
00466 - Control Module for Steering Column Electronics (J527)
00459 - Control Module for Display and Input; Front (J523)
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
Shop #: WSC 00000 000 00000
VCID: 2313EE3897C16A7FF75-5160
1 Fault Found:
00086 - Parallel Battery Connection Relay (J581)
011 - Open Circuit - Intermittent
No warning lights on the dashboard.
Did anyone experience the same?
Sorry for a lot of info...a bit freaked out.
Thanks a bunch!
Coding: 0007878
1 Fault Found:
Coding: 0405741
Component: ELV XXXX
1 Fault Found:
Coding: 0400325
1 Fault Found:
Coding: 0000107
1 Fault Found:
Coding: 0000212
1 Fault Found:
Coding: 0000157
2 Faults Found:
000 - -
Coding: 0000034
1 Fault Found:
Coding: 0022401
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 123
Time Indication: 0
Freeze Frame:
Voltage: 13.77 V
Count: 231
Component: Wische(
3 Faults Found:
014 - Defective
1 Fault Found:
Thanks a bunch!
This may be old news but keep the car on a battery tender. May I also suggest to get the batteries load tested. Should you need a left side battery make sure they sell you a AGM type. The right side battery is conventional liquid filled lead acid. Sometimes dying batteries will start triggering fault codes.
In any event a cheap and easy preventive maintenance check up.
I am certainly new to this, but I also agree with the "clear them" and see what pops up, I had some of those ("overhead electrical") that seemed to be simple nuisance faults that went away once the system was cleared. The "real" faults (in my case, exhaust flapper valve, exhaust temp sensor and one thermostat) came back and had to be fixed with a new thermostat, sensor and flapper valve.
My third-brake light was out, I got electrical faults that went away when it was replaced, does your brakelight work?
healthyspeed
Cayenne 958
Sep 14, 2023 12:38 PM
chriscmore
Jun 18, 2019 07:20 PM
Yotam Refael
Cayenne 955/957
Oct 4, 2015 07:59 AM
