Bentley Infotainment Rotary Dial Not Working
Old 07-12-2019, 01:56 AM
DAV3's Avatar
DAV3 is an unknown quantity at this point
Hello,
This morning I noticed my music wasn't playing in the car. I pressed the CD button and it said "CD player not available". I tried the Radio but that doesn't work either.
So I tried the satnav to see if it's an audio amp that's gone or something and I noticed that the rotary dial didn't respond on the screen to set an address.
The dial doesn't work for fan speed or suspension or anything. It rotates freely like you are using it to adjust something, but has no end stop (as you are not actually changing anything when turning it).
Has anyone experienced this before or heard similar. I read up and apparently you may be able to do a hard reset by pressing the reset button for like 15 seconds until the screen switches back on. So I will give that a go later.
I will plug in the VCDS when I get home if that doesn't work to see if anything comes up.
Any help will be much appreciated. Thanks.
Old 07-12-2019, 05:25 AM
DAV3's Avatar
So, it healed itself, all working now, so probs just a software glitch . . . ?
Old 07-19-2019, 09:05 PM
pwc6t3's Avatar
pwc6t3 is on a distinguished road
My 2004 GT had that problem. In the end I had to get a new head unit as I couldn't find a new replacement part. Hopefully yours will continue to work.
Paul
Talisman013
07-26-2022 03:59 PM
BWings
Bentley
08-07-2018 12:10 PM
Martin Perri
Bentley
06-11-2018 09:38 PM
pwc6t3
Bentley
20
04-19-2017 09:51 PM
alwaysurfing
03-10-2017 05:53 AM
Quick Reply: Bentley Infotainment Rotary Dial Not Working
