Rear window actuator
Old Sep 18, 2019 | 07:21 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Originally Posted by 1eapplebaum
More than likely the cable broke because the sliders fell off. Use Loctite so that doesn't happen again.😉
Here is the slider location. They go behind the area arrowed, opposite side of the exposed regulator in photo.
Old Sep 19, 2019 | 03:02 AM
5 Year Member
Originally Posted by Rico.Adams
Hello Roman, From the picture the part thats missing from the unit is the one marked in yellow, if not then from what I can see the only other place is circled in red ...
Hi M.Riico the referenced photo that I posted was an eBay offering only as a reference. Indeed it's missing the cover over the regulator drive wheel and a cable guide. The pieces in Mr.Roman's photographs are the nylon sliders that hold the movement in alignment. The sliders break or fall off causing the cable to bind and break. The white nylon sliders are on the opposite side of the unit on the convex slider guide. By the way a bit of white lithium grease on the guide will help the window move quietly.
Unfortunately the other side window mechanism probably has loose sliders or they've already fallen off. The day I fixed one side and tested the other side I heard the cable break on the other window.🤤
Old Sep 19, 2019 | 03:02 PM
Roman615's Avatar
Roman615 is infamous around these parts
Hello 1e ... I just found this pic & thought it may help, I cant comment on the mechanism as Ive never had the prevlage of opening one up, I did try to locate online a tech drawing for our friend with no luck.
I saw his post with the pic of the said part & it looked the same on the pic I posted I did mention I wasn't sure.
Im sure Roman will grease it all up before re installing the window mechanism ...
So everything is done, all back together, and working properly, thanks to you guys!!! Instead of the $1,400 I was quoted, it ended up costing me $110, all tolled. Now, I will admit, trying to accomplish all of this in 100 degree weather was no small task. In fact, there were a couple of times where I wish I would have just paid the other place to do it. But, with a little trial and error, and a lot of help from you guys, I am in the black $1,290. I think I will celebrate! Thanks so much to all of you!!!
Old Sep 19, 2019 | 04:33 PM
5 Year Member
3cheers mate😉👍
Johnny DB
Feb 26, 2014 11:04 AM
Lothar
Oct 6, 2013 02:32 PM
rotary rocket
Sep 28, 2007 12:56 AM
club411
Cayenne 955/957
Jun 15, 2007 08:26 AM
