Anyone used VCDS on a Speed circa 2008/9?
Have used a ross-tech hex-can usb cable/VCDS with an 06 and had no problem. Don't see any reason it wouldn't be the same for an 08/09 speed as I think they are standard VAG group OBDII connectors/systems.
edit... nevemind, I see your other thread and the trouble reading the trans section.
Likewise! I scanned an 06 no issues. The canbus wiring is radically different on 08 cars and different again on 09 cars. Also there is a different ABS unit on later cars.
I have an 08 Speed and VCDS struggles to read the transmission and ABS. Every other module is fine. It can read the transmission and ABS if set to K line mode instead of Canbus.
Hey dude
i tried and you Are Right. Transmission is not possible to read. Can you do something for me.
can you read coding of Heatin Controller. I want to See what is the Standard coding for this Unit.
mine is 0000111. i saw several cont gt some have 0000112 or 0000102. i have ac Problems since i own this car. Maybe they Changed Unit withoud codiing. Please let ne Know
Thank you
Thank you
Hey dude
Thank you
Thank you
Interesting that you have the same problem! Maybe you can post something to the Ross-tech tech support forum, they think its a fault with my car!
Can you scan the ABS?
I will plug in and check the heater coding tomorrow.
I'd be interested to see what ABS unit you have. HW and SW version etc.
Mine reports as:Address 03: ABS Brakes Labels: 3W0-614-511.clb
Control Module Part Number: 3W0 614 511 HW: 3W0 614 511
Component and/or Version: ESP 8.1 4WD H01 0250
Software Coding: 0002308
Work Shop Code: WSC 00083 790 00000
VCID: 6C81C3DF2A9DE46705D-5160
