Starting to notice the little things.
Old Apr 16, 2020 | 07:01 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Riding in the passenger seat (and that’s not often) I notice a little air whistling. Get home and it looks to me like the window is not flush, take a look at the other side and sure enough, it’s not.
Could this turn into a big problem? What remedies can I take to correct it?
Drivers side
Passenger side
Old Apr 16, 2020 | 04:26 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Door card removal and make the necessary adjustments to the alignment.
Old Apr 16, 2020 | 04:30 PM
Swflbt23's Avatar
Swflbt23 has a spectacular aura aboutSwflbt23 has a spectacular aura aboutSwflbt23 has a spectacular aura about
have you had any window repairs recently? if both windows operate normally without noise then they will need an adjustment. they never really sit flush because the door glass is on top of the rear glass. its not very fun to adjust. depending on which glass is out the door panel and/ or rear quarter trim will have to be removed. check the settings on the door if they are correct you adjust the rear glass to it. basically you work from the front of the vehicle to the rear setting all side glass. depth is 7.5mm from trim. insertion up into the seal i would compare to the known good side. as far are rear glass tension against front glass i usually use a dollar bill and shut it between the two pieces of glass. if you have solid uniform resistance on the dollar as you pull it out you are good to go compare to known good side as well
Old Apr 16, 2020 | 04:44 PM
Veteran: Navy
Thanks guys.. No glass issues the 2 years I’ve had it. This may be a job for the dealership 🤦🏾‍♂️
Old Apr 16, 2020 | 05:30 PM
AJ1's Avatar
AJ1
5 Year Member
So its been like that for years and its something that easily goes unnoticed. Rather than taking it to the dealership and paying their high labor rates, I suggest any auto glass shop, they'll have experience in this field.
Old Apr 17, 2020 | 06:25 AM
Veteran: Navy
Thanks for the input guys!
y2kgixxer
Jun 2, 2015 11:41 PM
caperss
Jul 24, 2013 02:06 PM
Zmoney
Jun 23, 2013 08:09 PM
Scott997
Nov 9, 2009 02:34 PM
ABCar
Oct 14, 2009 05:00 PM
