Continental GT Ticking Noise at Idle
Old Jul 5, 2020 | 08:50 AM
DaveGT's Avatar
DaveGT is infamous around these parts
I have a 2005 Continental GT Mulliner, 55,500 miles RHD UK car which has started ticking when sat at idle. The noise is very consistent and ticks slightly quicker than the second hand of a watch, when you lift the revs to approximately 900 RPM it stops. It appears to be coming from somewhere in front of the driver in front of the bulkhead. I’m struggling to establish what is the cause and hope that some can help me identify what it could be?
Old Jul 7, 2020 | 09:55 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @DaveGT ,
If you could post a video that may help, otherwise we are just guessing...
Does the tick speed up with any increase in rpms, is it like a valve tap, could it be oil pressure related, as in when you raise the RPM a hair it goes away, is it timing chain slap on the VVT, when was the last oil change, are you hearing a fuel injector clicking sound, or a evap control valve clicking, just so many items come to mind, so help us help you.
Johnny
Old Dec 16, 2020 | 11:53 AM
Jurgeenh Borbon's Avatar
Jurgeenh Borbon is infamous around these parts
My vehicle does the same thing, after some 10 min driving it goes away until I shut off the engine and let it get cold again, I'm thinking in add Sea Foam in the oil before the next oil change, and do an Italian tune-up in the highway.
With only 40k miles in the odometer, I really doubt in my case a loose timing chain.
Old Dec 16, 2020 | 12:39 PM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
Yours sounds like an exhaust leak
Old Dec 16, 2020 | 09:16 PM
An exhaust leak can sound very similar to a tappet or valve lifter noise?
My noise happens in front of the engine, I can hear it more pronounced in the passenger side bank, US spec.
Old Dec 16, 2020 | 11:43 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Has it ever had the front off to change the serpentine belt ?
Idler pulleys normally get changed as well as theses can get noisy.Like to see a vid thought?
Second the VAG alternator is water cooled .The two rubber o rings for the pipes perish and water seeps out .It can eventually ruin the a bearing .
It will be one of theses .
Old Dec 21, 2020 | 10:23 AM
I don't know if the previous owner replaced the belt, since the car is only 40K miles but has more than a decade I think he did it at some point, but I'll check that with my stethoscope.
Old Dec 23, 2020 | 11:40 AM
Yes a cracked exhaust can sound exactly like a bad lifter. It will go away as the engine gets hot and the manifold or pipes expand. I have used a stethoscope to pinpoint the noise.
Old Oct 13, 2021 | 04:38 PM
GH Bentley's Avatar
GH Bentley is infamous around these parts
That will be the purge valve, it is situated under the header tank on the right hand side (Bank 1) of the engine bay, If you put your ear to the wing around that area you will hear it, to stop it you have to remove it from its mounting bracket and cable tie it to it instead of the rubber mounting it uses.
Shaqovic
Bentley
Oct 21, 2024 03:41 PM
edinp
Bentley
Mar 30, 2018 08:58 AM
Chiaroblue
Bentley
Sep 17, 2017 03:03 PM
belton
Bentley
Jun 21, 2017 10:59 AM
WILLIAMHENRY
Dec 15, 2009 10:29 PM
