CGT Starter Battery Replacement Process
Old Sep 5, 2020 | 07:22 PM
Time2Go's Avatar
Registered PM
Time2Go is infamous around these parts
Greetings
Have just wrestled the dead starter battery out of the trunk of my trusty 2007 CGT. It being an AC Delco unit installed September 2014, so I'm not feeling too miffed. However, I got to reading several posts on the forum where references were made to installation sequences. One in particular mentioned severe damage, involving pyrotechnics, should the wrong process be utilized.
Can I ask whether this is a real issue of concern, or maybe some kindly misinformation put about by our friendly dealership folks? I'm well versed in the normal process, but the cluster of boxes and wires atop this puppy does inspire some fear.
Many thanks
Old Sep 6, 2020 | 08:56 PM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
There is a very specific process, there are multiple threads on here that take you through it.
I don't think you're going to blow the pyrotechnic wire-cutter, but this car is so sensitive to voltages that you should make sure you do it right. Scroll back through the pages and you'll find a couple good threads, they'll discuss how to reset your windows and whatever else got messed with.
Then again, you're just changing the starter battery, so if the other one is in good shape, that might all be for nought. But I'd still look it up. And I bet it's time to change your other one as well.
Sorry, I'm not a lot of help on this, but again, the thread is just a couple of pages back.
Old Sep 6, 2020 | 09:01 PM
British's Avatar
Here, I found one of them. Scroll down and you'll see a pdf.
https://www.6speedonline.com/forums/...y-dilemma.html
Old Sep 7, 2020 | 12:00 PM
Time2Go's Avatar
Registered PM
Many thanks for this. I agree that the tricky stuff seems to involve the house battery, what with seat position, steering, windows etc., so I went ahead with this one following the usual and customary process. All worked out fine and we're back in action. The house battery was replaced at the dealership under warranty and I keep it hooked up to a CTEK in the garage. As such I'm hoping for some additional time before handling that job.
As an aside, I've used a group 47 (H5) Duracell AGM, from Sam's Club, which is on special at around $127. They also have it in lead/acid for $87. The AGM also ranks at the top of its group at Consumer Reports. They come with a 36 month warranty.
Once again, thanks for the kind responses.
TeamJones1962
Bentley
May 5, 2018 07:27 PM
F430Spider
Bentley
10
Feb 1, 2017 12:24 PM
kensilver
Bentley
22
Nov 16, 2011 01:19 PM
ocd
Jan 18, 2010 09:07 PM
Val
Mar 4, 2008 12:17 PM
