2005 GT rear driver window stuck in down position
Old Sep 6, 2020 | 09:51 AM
ContinentalGT05's Avatar
ContinentalGT05 is infamous around these parts
any ideas? I recall there is a process to easily reset all the window function . However, I'm hearing a noise as I try to raise the windkw and the noise is consistent with cables not performing correctly.
Old Sep 6, 2020 | 10:41 AM
W. M. Hellinger's Avatar
5 Year Member
W. M. Hellinger is infamous around these parts
I suspect the sound you're hearing is the window regulator cable winding and wadding itself around the regulator's motor pully. Rather a "grinding/crunching" sound? If so: You'll likely need to replace that window regulator's assembly... chances are one of the plastic pulleys of the regulator failed... you might be able to just replace the broken pully and salvage the cable?
Old Sep 6, 2020 | 11:58 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @ContinentalGT05,
I have the 2005 unit listed in the marketplace.
Be aware that you can NOT use a 2006 or newer window regulator in any 2004-2005 as the 2006 and newer changed the bolt pattern for the mounting of the window motor to the regulator, been there done that..
https://www.6speedonline.com/forums/...d.php?t=389936
Johnny
Bozbomber
Jun 8, 2025 06:00 AM
nottoshabi
Oct 2, 2016 11:53 PM
lefizzet
Bentley
Jul 26, 2016 03:22 PM
jeffreym
Bentley
Sep 20, 2013 04:49 PM
white99c2
May 14, 2010 10:26 AM
