g85 steering sensor replacement coding required?
Old Sep 18, 2020 | 11:49 AM
crusher's Avatar
5 Year Member
crusher is infamous around these parts
im about to replace my steering control sensor as a complete unit with indicators etc from a breaker as mine shows as failing.
question do they have to be coded to the car ? also how do you do the alignment thing with vagcom ?
all advice appreciated
Old Sep 18, 2020 | 01:56 PM
crusher's Avatar
5 Year Member
ok before i took the plunge i tried to fit the sesor to my bentley wheel from a pheaton i had lying around..same part number but the gt says not coded to car and cannot speak to it..i thought being same part number there would not be an issue ?
Old Sep 19, 2020 | 05:02 AM
crusher's Avatar
5 Year Member
hi dark green ..i think you may be right as i think the steering angle sensor must be coded differently dispite the part number being the same.
i thought i would give it a try by replacing the steering angle sensor with one i had lying around off a pheaton before i took the plunge and ordered a used one off a bentley breaker for 500 quid..worth a go i thought but nope, the car could not communicate with it.
so when i fit the replacement full unit iv purchased will i need to code that to the car or will it be plug and play ?
Old Sep 19, 2020 | 06:53 AM
crusher's Avatar
5 Year Member
thanks for that info dark green i will check that later..
it appears that i may possibly have to calibrate it at the worst using my ross tech , i have sourced the info as follows should any one else have to recalibrate the
steering angle sensor and link is here it appears you can code the unit too but i dont feel experienced enough with ross tech to do it,
http://wiki.ross-tech.com/wiki/index...ch_5.7)#Coding
will keep posted with my endeavours
Old Sep 23, 2020 | 06:05 AM
crusher's Avatar
5 Year Member
ok..the new gearchange steering wheel sensor and indicator unit was swopped over today for a replacement unit i picked up from ebay for 180 quid.
fitted no problems about a 30 min job , but would not speak to rest of car so had to be coded as above, i couldnt do it on my software so nipped it to my indie who put iit on the bentley software and 10 mins later all is good , he had to pop some code into it then did a steering angle basic set.
just letting any one else know should they have the g85 steering angle fault throw up with all the abs lights etc.
good luck all
gbratk
Cayenne 955/957
Oct 31, 2024 02:26 AM
Wealth Manager
Mar 28, 2015 08:40 AM
Fugazi
May 2, 2012 11:34 PM
996ttDMB
Apr 23, 2008 05:06 PM
ColorChange
Jul 29, 2005 08:44 PM
