Gt v8s wobbling noise
Old Sep 24, 2020 | 12:18 PM
gfoxsteve's Avatar
gfoxsteve is infamous around these parts
I’ve got a wobbling noise coming from my car, think it’s under me in the bonnet area. Bentley dealer said new front struts which seemed extreme. Independent specialist change rol bar bushes etc but no different.
now being told it’s a characteristic of the v8’s, anyone else had this??
Old Sep 24, 2020 | 03:46 PM
MBi's Avatar
MBi
MBi is infamous around these parts
Unfortunately I don't believe I've seen that listed here before. Who's the dealer and the independent mechanic? Does the independent have a VAG scan tool that works for Bentley?
Old Sep 24, 2020 | 03:55 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
This certainly is not a "characteristic" of my V8S.
When you say a wobbling noise, ​​​​​​​can you be a little more precise ie. what is a wobbling noise ?
Old Sep 24, 2020 | 07:51 PM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Yes please be more specific. Does it gets more profound the faster you go? Did the shops check for a bent rim, hub barring or a broken belt in the tires?
Old Sep 26, 2020 | 05:47 AM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
If it’s got split rims , the bolts work loose .Ideally replace as they are single use stretch , but you can nip them up .
Buckled wheels are common too .= replace .
Old Oct 23, 2020 | 03:10 PM
gfoxsteve's Avatar
Update
Sorry didn’t get my notifications to tell me I had responses.
ive had new front suspension bushes fitted by independent dealer, they tried a rear air shock. Looked everywhere for anything loose etc
no error codes anywhere
more description, I here while rolling over bumpy ground at upto 10mph. It’s still there at higher speeds but road noise takes over
suspension setting makes no difference
Old Oct 23, 2020 | 03:14 PM
gfoxsteve's Avatar
No split rims and all running clear and balanced
the noise is a gentle continue knock but not metallic. That’s why I’m describing it as a wobble rather than a knock
Old Oct 23, 2020 | 03:18 PM
AJ1's Avatar
AJ1
5 Year Member
What tyre pressures are you running ?
Old Oct 23, 2020 | 03:20 PM
gfoxsteve's Avatar
I’m not near the car now but running at the recommended pressures for the mid setting which I thinks for “high speed”
maybe upper 30’s
Old Oct 23, 2020 | 03:25 PM
AJ1's Avatar
AJ1
5 Year Member
Front should be mid 40's, however your upper 30's wouldnt be a problem. I thought perhaps you had way too much in there.
I dont understand quote "they tried a rear air shock" - given that you described the problem noise coming from the front.
Old Oct 23, 2020 | 03:36 PM
gfoxsteve's Avatar
Yes one of their techs was convinced it was a transferred noise from the rear, I wasn’t.
they tried changing the air shock and it made no difference
Old Oct 26, 2020 | 10:59 AM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
If the suspension is tight start looking for loose body panels, bumpers or fastener issues.
Shaqovic
Bentley
Oct 21, 2024 03:41 PM
DaveGT
Bentley
Oct 13, 2021 04:38 PM
MulsanneTurbo
Bentley
Jun 19, 2020 04:06 PM
edinp
Bentley
Mar 30, 2018 08:58 AM
Chiaroblue
Bentley
Sep 17, 2017 03:03 PM
