Suspension Pump
Old Nov 6, 2020 | 03:59 PM
Nader's Avatar
Nader is infamous around these parts
Suspension Pump
So my suspension has been dropping in the front at the same rate on both sides. I decided to check the distribution block in the rear to see if there were any lose fittings. Well I didn’t see any obvious leaks as I sprayed soapy water liberally on them. They were however pretty lose. I couldn’t turn them by hand but with a short 10mm wrench they all were very easy to turn so I snugged them all. We will see if that helps any. I think it’s possible. My Supersports has only 7009 miles so can’t see the air babes going.
well anyways while down there I notice the pump itself was lose. Not the bolts themselves but the bushings it’s mounted on seemed too lose.
any thoughts?
Old Nov 7, 2020 | 01:45 PM
Nader's Avatar
For some reason I can’t get the video to upload.
Old Nov 9, 2020 | 02:49 PM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
When does it drop? Overnight? Does it take a few days to drop if you don't use the car?
I would think the pump should be mounted on rubber bushing to shield the vibration.
Old Nov 9, 2020 | 06:03 PM
Nader's Avatar
The suspension would drop over a 48 hour period. Initial review of the adjustments I made look promising. Hasn't dropped at all yet. Fingers crossed! The pump is mounted on studs with rubber bushings but seems too easy to move and there is a lot of play in it. Wass hoping to post the video but doesn't work.
jzchen
Feb 28, 2020 01:50 PM
gtjay
Bentley
27
Sep 10, 2019 07:33 AM
hollynitro
Jan 29, 2016 11:29 AM
sparky2150
Cayenne
Feb 22, 2014 06:23 AM
550bryan
Jan 14, 2014 09:01 AM
