Brake light warning .
Old Apr 5, 2021 | 05:48 AM
Tony Cocks's Avatar
Tony Cocks is infamous around these parts
I run a 2009 Continental GT which has developed an intermittent fault .
On some occasions when I apply the foorbrake a warning " beep " sounds and a message appears on the dash
" Check brake lights. Fault. "
There is in fact no problem with any of the brake lights, and the warning is not always there when the footbrake is applied .
The message then disappears but appears again at random.
Anyone have any ideas ?
Old Apr 5, 2021 | 03:36 PM
Tony Cocks's Avatar
I've checked on numerous occasions and found all of the LED's working .
The fault has now cleared again , but no doubt will be back when I next drive the car !
Old Apr 5, 2021 | 07:46 PM
Johnny Hotspur GT's Avatar
Administrator
How about the 3rd brake light ?
Old Apr 7, 2021 | 02:28 AM
Tony Cocks's Avatar
The third brake light works fine !
Old Apr 7, 2021 | 02:42 AM
Administrator
Do you have any signs of moisture in the 3rd brake light, or either tail light ?
Johnny
Old Apr 7, 2021 | 03:00 AM
Tony Cocks's Avatar
No I can't see any sign of moisture in any of the light assemblies.
Old Jul 31, 2023 | 11:31 AM
Mechs's Avatar
Mechs is infamous around these parts
I have same problem with flying spur
Did you solve the issue?
I would appreciate if you could tell me how you solved.
Old Jul 31, 2023 | 12:29 PM
Tony Cocks's Avatar
I ended up having a high level brake light replacement .
Expensive job at £800 !
Old Aug 1, 2023 | 11:56 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
high level - you mean the 3rd light? on top of the rear window?
Old Aug 1, 2023 | 01:09 PM
Tony Cocks's Avatar
Yes, that is correct .
Old Aug 1, 2023 | 03:26 PM
Administrator
Hello ​​​​​​@sazam ,
As per Bentley, it is called the "CHMSL" or "central high mount stop light", so if you ever search for it on Scuderia or Flying Spares, you won't find it under the search "3rd brake light".
Johnny
ContinentalGT05
Bentley
Sep 15, 2020 05:55 PM
darrenre
Bentley
Jun 28, 2020 09:15 AM
fromwrxto330ci
Aug 26, 2016 03:09 PM
Ph3n0m
May 7, 2012 06:45 AM
anikzad
Jul 26, 2010 10:09 AM
