Ben-HUR installs again
Old May 15, 2021 | 04:45 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
We are getting there! Unit had to go back the factory for repair, but now is working as it should.
However, the head unit is mis-wired to the rear outputs, not front, so none of the sat nav announcements or phone call via car play work
Anyone know how much space is likely to be behind the DIN unit? in theory I should be able just to pull the head, connect it correct and re-install it, but I have a nasty feeling that the Ben-HUR and the head have been rather closely cabled together. So wondering if I might be able to squeeze a hand down the back if I remove the speaker grill and the wood trim.
Any thoughts?
C
Old May 15, 2021 | 06:59 AM
Iain 1250's Avatar
5 Year Member
Iain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud of
Not much chance of getting your hands behind from above, you will need to pull the whole Ben Hurr unit out.
Old May 15, 2021 | 12:07 PM
CatmanV2's Avatar
5 Year Member
Thanks! That saves me a job. The guys that put it back in have already volunteered to come round one evening and sort it out, so can't say fairer than that!
C
Old May 16, 2021 | 09:56 AM
CatmanV2's Avatar
5 Year Member
Did it myself this evening. Very simple. Trim remove to get the speaker grill. Bit of a shove to get the wood off then 4 screws.
C
LagunaSecaC4S
Dec 29, 2016 10:44 PM
smistry007
May 26, 2013 09:57 AM
Arnie
Jul 13, 2004 08:12 AM
