05 Continental when hot not starting
Old Sep 28, 2021 | 01:37 PM
Felix Smolensky's Avatar
Felix Smolensky is infamous around these parts
Hi! Need advice , when vehicle is cold , its starts normally , but when its getting to the normal operation tempature if i turn the cehicle off its not gonna start again till its cool down.
No errors. Thank you in advance!!!!
Old Sep 28, 2021 | 01:49 PM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Worth scanning for errors. Typically Maseratis do this when the CPS is failing. This may not be helpful information
C
Old Sep 28, 2021 | 03:46 PM
Johnny Hotspur GT's Avatar
Administrator
Hello ​​​​​​@Felix Smolensky,
As CatmanV2 stated, failing CPS, as a failing CPS = crank position sensor will give you exactly what you describe, with no fault code / check engine light, or if you scan engine ECU'S 1 and 2 you may find an Intermittent CPS fault, but you must scan with the proper tool, like Ross-Tech VCDS.
The CPS with part number 070 907 601A is located on the transmission at the 6 O'clock position.
Johnny
The last picture above, is the CPS with it's connector broken off...
Last edited by Johnny Hotspur GT; Sep 28, 2021 at 03:50 PM. Reason: Add part number
Old Sep 28, 2021 | 05:04 PM
Thx for replies guys! Gonna check tonight.
Old Sep 28, 2021 | 05:26 PM
Administrator
​​​Hi @Felix Smolensky ,
Just to be specific, I as many call it a crank position sensor/CPS, but it's technical name I guess is that it is a engine speed sensor / ESS aka G28.
I just didn't want you looking for the wrong item.
Johnny
Old Sep 29, 2021 | 02:33 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
A few years ago, I experienced a similar problem. For reference, please see: won't start when hot - 6SpeedOnline - Porsche Forum and Luxury Car Resource
Old Jan 18, 2022 | 07:42 AM
GTO68's Avatar
GTO68 is infamous around these parts
Hello,i have the same problem,car wont start when hot,after 1 hour waiting it starts normally,no engine light on,Felix did you fix it? was it the Cps?
thx
Benebasil
Bentley
17
Jan 6, 2025 12:39 AM
neiloakley
Bentley
31
Jan 10, 2022 11:29 AM
Joe Boccia
Bentley
Nov 25, 2016 11:41 PM
