Air Intake Temperature Sensor Issue 2004 GT
Old Apr 7, 2022 | 04:16 PM
V12diablo's Avatar
V12diablo is infamous around these parts
After several weeks of getting a electrical issue fixed on my new to me 2004 GT. I have one code that I can't figure out.
This is the code and the full scan is below.
19490 - Intake Air Temperature Sensor 2 (G299)
P3034 - 002 - Signal too Large - MIL ON
According to IETIS that sensor is the one located on the driver side intake manifold. I have replaced the sensor and have done a ohm test on the wiring from the connector to the ecm and have good continuity. I'm just wondering what else I should be looking for?
Thanks in advance.
Jason
{code}
Code:
Wednesday,06,April,2022,20:07:57:53661
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.1 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220401 DS337.0
www.Ross-Tech.com
VIN: SCBCR63W04C022240 License Plate:
Mileage: 168790km-104881mi Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCR63W04C022240 Mileage: 168790km-104881miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 J HW:
Component: BY-6.0L-TT G ª6240
Coding: 0000173
Shop #: WSC 01666 772 36780
VCID: 2C010BE8AA162EBB432-5160
VINID: 8D34938860E70044C008208400746ACBC3
2 Faults Found:
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 001 - Short to Plus
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 D HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1904
Coding: 0000101
Shop #: WSC 00000 000 00000
VCID: 313F1A9C8D344353704-5160
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 F
Component: ESP 5.7 4WD H01 0047
Coding: 0007878
Shop #: WSC 12345 000 00000
VCID: 382927B86E4E921B37A-51CE
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: 11 Kessy 6400
Coding: 0131309
Shop #: WSC 00083 000 00000
VCID: 2F3B1CE49B0055A3660-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 34183 002 1048576
VCID: 47CB544413B0EDE34E0-5160
5 Faults Found:
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
005 - No or Incorrect Basic Setting / Adaptation
01975 - Passengers Seat Height Adjustment Motor (V191)
01904 - Passengers Backrest Adjusting Motor (V46)
01903 - Seat Tilt Adjustment Motor (V231)
01976 - Seat Depth Adjustment Motor (V234)
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 FX
Component: ZAB COCKPIT 0251
Coding: 0400325
Shop #: WSC 03224 104 175128
VCID: 084997785E2E229B87A-5160
1 Fault Found:
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000002
VCID: 30391F98863E4A5B7FA-5160
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 G
Component: STG.Bordnetz 5001
Coding: 0000107
VCID: 2E0501E09C0A5CAB6D6-5160
1 Fault Found:
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Coding: 0000173
1 Fault Found:
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2517FECCC9FC1FF39CC-5160
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 Q
Component: KOMBIINSTRUMENT RB8 0401
Coding: 0023200
VCID: 42DD45503892C8CB99E-5160
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9DF9846BE0A5B3FA-5160
1 Fault Found:
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
VCID: 77ABE48423D05D63FE0-5160
3 Faults Found:
01400 - Suspension Level Control
002 - Lower Limit Exceeded
01583 - Leak in System Detected
000 - -
00778 - Steering Angle Sensor (G85)
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
VCID: 3FDB4CA44B60A523F60-5160
6 Faults Found:
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
01895 - Motor for Steering Column Adjustment; Vertical (V123)
01896 - Motor for Steering Column Adjustment; Axial (V124)
Address 37: Navigation Labels: None
Part No: 3W0 919 887 A
Component: NAVIGATION 0168
Coding: 0400000
VCID: 45D75E4C29BCFFF3BCC-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0702
Coding: 0000189
VCID: 36352980645A646B256-5160
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 1F HSG 0101
Coding: 0000032
VCID: 3333109477287143028-4B00
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Component: TSG HL No Answer
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
2 Faults Found:
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
VCID: 343113887226767B1B2-5160
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022401
VCID: 35372E8C795C6F732CC-5160
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 30391F98833E4A5B7FA-51A8
Address 65: Tire Pressure Labels: 3D0-907-273-V1.clb
Part No: 3W0 907 273
Component: Reifendruckueberw. 0022
Coding: 0010344
Shop #: WSC 03236 104 61216
VCID: 76B5E98024DA246BE56-5160
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2313E0D4C7C8E1C3F28-5160
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AADFDB010C2400B81E-5160
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
End----(Elapsed Time: 06:18, VBatt start/end: 13.7V/13.9V. VIgn 0.0V)------
Address 11: DTCs cleared
{code/}
Old Apr 8, 2022 | 03:33 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Hello V12,
The posted scan reveals multiple trouble codes including the air temperature sensor. Delete the DTC's at each address or try the universal delete option. Sometimes deleting trouble codes @ each address is better.
Now verify the batterys' integrity. Testing with a voltmeter is not sufficient. A load test should be performed on both batteries... most part stores can load test. The number of trouble codes are possibly caused by weak batterys.
Anyway short of load testing, delete the trouble codes drive the car and rescan.
E
c0ke
Bentley
43
May 11, 2024 05:44 PM
pupdogg
Bentley
Oct 17, 2021 05:02 PM
Realdeal12
Bentley
14
Jan 26, 2021 06:14 PM
rich9911
Bentley
Feb 20, 2020 01:27 AM
