07 Air Condition Issue
Old Jun 16, 2022 | 10:47 AM
Dirk989's Avatar
Dirk989 is infamous around these parts
Took my 07 to my independent mechanic. They always do great work without the dealer price gouge.
My air conditioning has quit working. Compressor, which appears to be new, won’t kick on.
The mechanic said he narrowed it down to a control module which would need to be replaced and reprogrammed at a dealer.
I know this isn’t much information, but does anyone have any other perspective or ideas?
Is the control module compatible with an Audi or VW part?
Thanks for any advice you may have.
Old Jun 21, 2022 | 07:10 AM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
First thing to do to narrow this down prior to throwing yourself at the mercy of the dealer is to buy a Ross-Tech scanner and download the error codes. Without knowing what the car is telling itself, we can't do any sort of online trouble-shooting.
Buy the Ross-Tech, then post the results.
It is very possible that it is a module, I had a weird problem where it strarted to throw out moist, warm air on a hot day. I stopped the car, put it in park, turned the car off, took the key out, then started it back up and everything worked fine. So "CNTL-ALT-DEL" can work, this thing is so computer-controlled.
If the Ross-Tech says "module XXX" you'll know more.
Mark_Havant
Cayenne 955/957
Sep 18, 2019 05:04 AM
Arachnophobia
Bentley
Jul 12, 2017 09:57 PM
LosAngeles
Cayenne 955/957
Feb 4, 2010 12:28 PM
mattjtaylor50
Cayenne 955/957
Sep 24, 2009 08:42 AM
