'06 BCGT Driver Side Seat Memory Fail
Old Oct 21, 2022 | 06:30 AM
jslamin's Avatar
5 Year Member
jslamin is infamous around these parts
For no explained reason, yesterday the driver side seat memory has failed. The automatic forward motion when the seat is tilted forward for a rear passenger has also failed. I have done the factory initialization twice for the seat with no success. The passenger seat works properly. What should I look for?
Old Feb 10, 2023 | 04:28 PM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
exactly the same problem on my side. any ideas? did the manual procedure to reset 2 times and no success - passenger side ok , driver side no memory and no move when tilting forward etc
Old Oct 16, 2023 | 07:14 AM
jslamin's Avatar
5 Year Member
Seat memory problem solved
I solved my seat memory problem, that was exactly the same as yours. Including the front/back motion when the seat is tilted forward. The attached factory instructions must be followed exactly for it work. PDF attached. These instructions are different than was reported on this website.
Good Luck. JS
File Type: pdf
Old Oct 19, 2023 | 08:37 AM
DannyGTCRichmond's Avatar
DannyGTCRichmond is infamous around these parts
As noted in the detailed instructions the key to it is to reset the steering column too. Mine goes quite often.
Old Oct 21, 2023 | 02:46 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Reset per the factory manual - moving in all directions to the stop points, holding for 10 seconds at each stop point. Also same for mirrors and steering wheel.
rohnin
May 19, 2022 05:01 PM
Cheebs
Cayenne 955/957
Aug 5, 2021 02:48 PM
randyb
Jan 31, 2017 10:20 AM
randyb
Aug 10, 2016 04:08 PM
DoninDEN
993 Turbo
Aug 6, 2013 06:25 AM
