gt 2005 - missing parts
Old Jan 16, 2023 | 12:27 PM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
hi,
i noticed there is something missing here. can anyone help me and send a photo how it looks like and what is the part number so i will try to buy it?
Old Jan 16, 2023 | 01:42 PM
Johnny Hotspur GT's Avatar
Administrator
@sazam ,
You are missing the complete lock and latch assembly for the pass-thru.
The lock cylinder would be coded to your key-blade, so if you buy a used piece for parts, your key would not fit to turn, I know I swapped cylinders, but you could also just remove the tumblers in the used part you purchase, if you don't care about it locking.
Johnny
Originally Posted by sazam
hi,
Old Jan 16, 2023 | 02:55 PM
sazam's Avatar
ty John - how to get inside? i here there is smth loose - looks like the ofher part of the lock
Old Jan 16, 2023 | 05:14 PM
Administrator
@sazam ,
You pull the carpet gently off of the other side of the pass-thru flap, then glue it back on when done.
As far as parts, I found something a little confusing, as number 11 (the door/flap) is not available separately, it comes with number 1 (the complete carpet panel along the rear seats), but then it states "BIN 083702" pointing to the lock, when I look up such BIN, it only shows a complete lock set for the whole car, were some other locks are available separately, I can not find this lock separately, BUT numbers 12, 13, and 20 not only point to the side panels, but also to the number 1 piece that consists of number 11, and notes manual locking, not sure what that means, as either way, the lock is locked manually by hand be it by key or thumb dial.
Your photo looks a little odd because I can see the blue insulation right up against the hole, with no depth, maybe it is just the camera, and your door doesn't have the 4 ribs.
Johnny
Old Jan 16, 2023 | 05:38 PM
Administrator
@sazam ,
Please be sure to see post number 4 above, as I am posting back to back... I know 🫣.
Here are the parts as per numbers 12, 13, and 20, that is if they do work for said pass-thru door.
It would be interesting if others who have or had a 03 and up first Gen GT, if they could share if their pass-thru door had/has a key cylinder, or a thumb lock.
Johnny
Old Jan 16, 2023 | 06:16 PM
Mars911's Avatar
Mars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond repute
Pass through Door ****
My 2005 GT just has a **** and not a lock
2005 GT pass through door
Old Jan 16, 2023 | 06:41 PM
Administrator
Wow ! Great news @Mars911 !
Thank you for sharing.
There you go @sazam , see the three parts and they numbers above.
Johnny
Old Jan 16, 2023 | 11:06 PM
sazam's Avatar
Johnny - youre amazing! thank you so much.
All of the bemtley forum members are great!!!
Thank you guys for help!
what is the part number for a **** (not lock)
Old Jan 18, 2023 | 06:42 AM
sazam's Avatar
hi guys,
another missing elements, anyone can check what is the part number to look for please?
sorry for mess but now i am focused on different details of fixing or completing missing elements,
time for aesthetic surgeries and treatments will come soon
Old Jan 18, 2023 | 12:03 PM
Administrator
Hello @sazam ,
Here you go.
Johnny
Old Jan 18, 2023 | 12:48 PM
sazam's Avatar
thank you so much Johny...
btw - i found this element in the glovebox - what is this ? smth from bentley?
Old Jan 18, 2023 | 01:52 PM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
Looks like a snap on cover with a broken clip for some opening but no idea where. Since it's marked LH maybe something on or under the dash or in the glovebox?
Old Jan 18, 2023 | 02:38 PM
Administrator
@sazam ,
I'll give you 3 guesses....
Johnny
sazam
Bentley
Jan 13, 2023 01:06 PM
BentleyF
Bentley
Oct 18, 2016 12:35 AM
SRatha
Maserati
Dec 16, 2008 09:02 PM
