Bentley GTC 07 Brake switch fault? Rodent damage? Trans problems?
Hi Everyone,
Been lurking on here for some time, thanks for the resources......
I have a problem with my 2007 GTC
Car was fine, not used every day, last week when i started the car the EDC light came on and the car only works in manual shift using the paddles, it also starts without putting foot on the brake.
I have looked under the bonnet and found a wire that appears to be chewed and rodent foot prints in the dust around the engine bay.
Have run a scan with VCDS, this returns the errors as below but points to the brake switch / communication, found very little about this on the internet, I now believe that the wiring is probably damaged under the bonnet etc. unless anyone knows any better?
I know very little about the wiring harness locations etc, would anyone have any ideas where the issue is or locations likely to have been damaged to cause this fault?
Here is some of the VCDS log (the full fie is attached):
Friday,03,March,2023,10:30:15:17704
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
VIN: SCBDE23W87C048825 License Plate:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBDE23W87C048825 Mileage: 94520km-58732miles
Address 01: Engine Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 EL HW: 07C 906 018 EC
Component: BY-6.0L-TT NC G ª0594
Revision: --H01--- Serial number: VWZ3Z0G3585956
Coding: 0011175
Shop #: WSC 00083 790 00000
VCID: 73B3CCD1C7A17A12021-5160
VINID: 8D34945420E72074C0108202148BBED1DD
2 Faults Found:
001349 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0545 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 28
Reset counter: 255
Mileage: 93152 km
Time Indication: 0
Freeze Frame:
RPM: 913 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 32.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.684 V
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 94511 km
Time Indication: 0
Freeze Frame:
RPM: 1465 /min
Load: 35.3 %
Speed: 18.0 km/h
Temperature: 69.0°C
Temperature: 11.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 AA HW: GS1 911 4
Component: AG6 09E 6.0L W12TT 2811
1 Fault Found:
P0571 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 512 /min
RPM: 96 /min
RPM: 0 /min
(no units): 23.0
(no units): 29.0
Temperature: 34.0°C
T.B. Angle: 0.0°
Many thanks and any input greatly appreciated
Regards James Lewis
Coding: 0011175
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Reset counter: 255
Mileage: 93152 km
Time Indication: 0
Freeze Frame:
RPM: 913 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 32.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 94511 km
Time Indication: 0
Freeze Frame:
RPM: 1465 /min
Load: 35.3 %
Speed: 18.0 km/h
Temperature: 69.0°C
Temperature: 11.0°C
Voltage: 13.462 V
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 512 /min
RPM: 96 /min
RPM: 0 /min
(no units): 23.0
(no units): 29.0
Temperature: 34.0°C
T.B. Angle: 0.0°
Regards James Lewis
Hello @themadsparkie ,
I was just about to post on your first comment after getting it approved, but I see you found the issue now.
I had the same with the EPC ABS and traction control lights on, it turned out to be the brake light switch, my rebuild thread at post number 284 tells of all the issues it caused.
https://www.6speedonline.com/forums/...-pictures.html
Johnny
Johnny
