gt 2005 - removal cigar socket in the central panel
Old Mar 16, 2023 | 09:11 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
yes i did, the rear lighter when put into the front socket, is not "holding"
when it is in back socket, it is "holding"
and vice versa - front lighter put into rear socket is "holding"
while having it in front socket is not "holding"
Old Mar 16, 2023 | 09:18 AM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
Maybe the socket is worn and just need to be changed. You might even be able to bend the metal a little to fix it. Guessing the car was owned by a smoker who used it a lot or maybe stuck and odd shaped charger in it and bent something.
Old Mar 16, 2023 | 09:30 AM
sazam's Avatar
both lighters are like brand-new, probably bending issue, however this function is smth like temperature releasing metal stuff, so if i will start bending wondering it even will work as expected.
sazam
Bentley
Jan 20, 2023 01:31 AM
sazam
Bentley
Jan 19, 2023 09:09 AM
Hannibal73
Bentley
Nov 11, 2022 12:23 PM
Randy V
Bentley
Dec 29, 2021 01:21 PM
jc_333
Bentley
Jul 23, 2012 05:15 AM
