05 battery area old vent pipe?
Old May 30, 2023 | 02:39 AM
TimeforaTee1's Avatar
TimeforaTee1 is infamous around these parts
Hi, Just bought an 05 Bentley continental gt while sorting/checking the car over came the apparently usual split spoiler drain pipe and a spare wheel well swimming pool! Also a 1/2 inch of water in the starter battery area, had it all out to dry and clean, came across a black pipe not connected to anything my best guess is a redundant battery vent pipe could anyone confirm this also came across a small plastic item anyone got an idea what it is and where it goes?
Many thanks Chris.
Small plastic item found in battery area
Unattached black plastic hose from batter area
Old May 30, 2023 | 06:10 AM
DesotoJohn's Avatar
DesotoJohn is infamous around these parts
The small tube is a battery vent pipe. Not sure what you mean by "redundant", unless your batteries both have one fitted? I had both tubes in my 2014FS, but neither was attached to the battery! The other item appears to be part of a trim piece (hardboard panels) attachment cam. Mine are two piece; one piece is what you turn and on the back side there is a plastic piece that catches to hold the trim in place. My guesses! I hope everything dries fine!
Old May 30, 2023 | 12:56 PM
Hi, Many thanks for the confirmation, the battery currently fitted has no where for a vent pipe so temporarily redundant.
Regards Chris.
Old May 30, 2023 | 04:18 PM
DesotoJohn's Avatar
Please check your battery carefully and make sure the vent is not plugged. Many are shipped with removable plugs on both sides to accommodate installation of a vent on either side. The correct battery for this vehicle would have a vent port and I would anticipate it extends the life of the battery.
Old Jun 3, 2023 | 03:59 PM
Hi thanks for the advice the battery manufacturers spec makes a deal over roll over leak proof design but doesn't mention anything about requirements for a vent, however there is a small hole where a vent would normally be I did assume this to be blind moulding hole but I've popped the vent pipe into it, if nothing else it looks neater! Also thanks for the ID on the plastic clip it is a battery access panel cam but all mine are Intact so I've got a spare.
Many thanks Chris
ciaka
Cayenne 955/957
Sep 9, 2022 06:53 AM
JStiles01
Bentley
22
Jan 31, 2022 07:27 PM
steve knight
Bentley
Apr 3, 2021 02:44 PM
Tobanla21
Bentley
31
Sep 28, 2019 01:20 AM
Forster1993
Bentley
Oct 19, 2017 03:52 PM
