Headlight internals - Xenon module type?
Old Nov 26, 2023 | 06:22 PM
hq_'s Avatar
hq_
5 Year Member
hq_ is infamous around these parts
I've done quite a few HID retrofits over the years and taking headlights apart for replacing their internals is nothing new to me.
Now, the OEM HID xenons of my FS are slightly aged. The pattern is a bit fuzzy and this is typical to modules with faded reflectors. So they're due for replacement. Instead of simply getting a pair of new headlights, which is stupid expensive, I'm now researching the possibility to take them apart and replace the bixenon modules in them. I just don't have a clue what type of modules the OEM:s are, what's their bolt pattern, what are their dimensions and so on.
Can anyone help me with this? I've used a few E46-R -type modules with fantastic success in the past and if these are compatible, the problem is solved. I could just figure out this myself by pulling them apart, but I'd much rather have a set of replacement modules at hand when i do it.
I might put together a DIY-upgrade thread afterwards. Modern bixenon modules are way brighter than 10+ year old OEM:s were when they were new - and bi-led modules aren't bad either - so this is all about functionality.
Thanks.
Old Nov 27, 2023 | 06:34 AM
hq_'s Avatar
hq_
5 Year Member
Come on. Someone MUST have a broken headlamp or some kind of information about this. The bolt pattern and seating depth are crucial information for this. I assume it's a Hella unit, but there are a few compatible options out there, some with better light pattern and output.
Any help is much appreciated, even a photo of a broken headlight (from behind) will help.
Old Nov 27, 2023 | 06:46 AM
hq_'s Avatar
hq_
5 Year Member
Here's an example, only taken from the "wrong" side in order to figure out the mounting requirements of the modules themselves. This is just about the best picture I could find online and unfortunately it's not good enough.
Red5
Cayenne 955/957
Dec 27, 2020 08:46 PM
jonguffey
Cayenne 955/957
Sep 23, 2020 10:07 AM
Don hitchman
Cayenne 955/957
Dec 7, 2018 06:39 PM
SRatha
May 12, 2009 07:43 AM
motoadve
Cayenne 955/957
Nov 20, 2008 09:36 AM
