Zenon headlight
Old Dec 7, 2018 | 05:16 PM
Don hitchman's Avatar
Don hitchman is infamous around these parts
Zenon headlight
I had to go to a dealership to get the low beam zenons adjustment done. It can only be done by computer, no manual adjustment on the low beams.
my question is if I have to unplug the headlight assembly from the vehicle harness, does that previous setting get stored in the headlight control module in the housing, or if I have to get it reprogrammed again?
Old Dec 7, 2018 | 06:28 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
It is stored - doesn't matter where as long as you're not changing the headlight.
Old Dec 7, 2018 | 06:39 PM
Zenon headlight
Thats my problem...the driver's side headlight assembly leaks and has major condensation. The right side is perfect and never gets condensation.
So, I have another headlight assembly that is used but in perfect condition. It evidently needs a bulb or ballast. I have recently changed both(sides) lowbeam bulbs, and have the ballasts etc to put into the new housing.
My question originally was where the settings were stored in memory, and thanks for the reply, but it didn't answer my question.
BCS996TT
Cayenne 955/957
17
Dec 7, 2018 06:51 PM
motoadve
Cayenne 955/957
Nov 20, 2008 09:36 AM
BD 997
Cayenne 955/957
May 10, 2007 08:07 AM
akinla
Apr 25, 2007 02:44 PM
